Page 1 of 4 1 2 3 4
Best brand rebuild kit 2.6 #1072646 06/26/14 05:49 PM
A
Airsailor Offline OP
Replaced my 2.6 with a 4.3. Now I have this 2.6 sitting on a stand. I'd like to rebuild it. Mostly because I invested in a marnal head and a few other parts before the swap. My question is, who makes the best stock rebuild kit. In best I mean quality. Thanks in advance.
Re: Best brand rebuild kit 2.6 [Re: Airsailor] #1072647 06/27/14 12:08 AM
Engine Machine Service has a good rep. Be sure you get Montero pistons, not starquest...
Re: Best brand rebuild kit 2.6 [Re: fasteddy] #1072648 06/27/14 01:48 AM
Malykaii Offline
I got beat to it. Yes, speak to randy at ems. He has rebuilt a bunch of 2.6 for the starion community. He also stocks hard to find and oem components.
Regarding a kit... there realy isnt one that embodies all the good stuff. I'd say get the felpro gasket set, sealed power or clevite bearing, and hastings non chrome rings.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: Best brand rebuild kit 2.6 [Re: Malykaii] #1072649 06/27/14 03:25 PM
Kevin C Offline
Stock rings on a 2.6 are chrome and seem to hold up quite well.
Good info on rings materials
I have been running chrome rings on my turbo 2.6 engines for a long time with no issues.
Moly is a good choice as well, with better scuff resistance, but is not as good off road in a dusty environment.
With good block prep, either will give good service. The best tip for good oil control and compression is to make sure the ring gap on the second ring is wider than the gap on the top ring. This assumes that the top ring has the correct minimum gap.
Re: Best brand rebuild kit 2.6 [Re: Kevin C] #1072650 06/27/14 11:34 PM
Malykaii Offline
I should have explained better. Chrome is oem and will last the longestn however its harder to get to seal. Like if you plan to have your block sent out and properly bored and/or honed, then sure. However I rebuild my motor still in the truck with the crank still in. I honed it with a harbor freight hone and $15 drill. I have perfect compression and oil pressure. So depends on your needs.
Plus regarding lifespan, I still think the moly rings will outlast a head gasket, so if the headgasket goes, your already 3/4 the way in for a re-ring.
Re: Best brand rebuild kit 2.6 [Re: Malykaii] #1072651 06/28/14 01:26 AM
I usually defer to KevinC on stuff like this, but I really like moly rings. I'm not driving in a quarry, and I use good air filters. I realize that I'm sacrificing some engine life, but I drive maybe 98% pavement, and the rest dirt, usually not following a dust cloud maker. I don't think I lose enough engine life to make chrome preferable over moly.
Make sure you home according to the ring material used. Different materials use different honing pattern specs.
From a mfr of hones:
Cylinder Ring Type:
OEM Iron rings: 180 or 240 grit
Chrome rings: 240 or 320 grit
Moly Rings: 320 or 400 grit
Plasma Rings: 320 or 400 grit
not sure ring type: 240 grit
Re: Best brand rebuild kit 2.6 [Re: Malykaii] #1072652 06/28/14 03:42 PM
Kevin C Offline
I should have explained better. Chrome is oem and will last the longest however its harder to get to seal. Like if you plan to have your block sent out and properly bored and/or honed, then sure. However I rebuild my motor still in the truck with the crank still in. I honed it with a harbor freight hone and $15 drill. I have perfect compression and oil pressure. So depends on your needs.
What brand of rings did you run? I have always had good results running either Sealed Power of Hastings. Looks like Randy (aka Dad) has most important parts. Were you able to reuse your old pistons or did you go for new ones? I'm assuming this was for a 87-89 2.6?
I have a spare 2.6 that I might be getting back on the engine stand.
Re: Best brand rebuild kit 2.6 [Re: Kevin C] #1072653 06/29/14 01:31 PM
A
Appreciate all the info. I have a marnal head and ajusa complete gasket kit. Should I put 1mm oversized valves and heavier springs in it? Should I stick with cast pistons? This will never be used for serious off road. My intentions for the motor is to be placed into a basket case Raider.
Re: Best brand rebuild kit 2.6 [Re: Airsailor] #1072654 06/29/14 05:02 PM
Kevin C Offline
Stock valve springs and stock sized valves would be my recommendation.
Cast pistons offer the best combination of features for longevity and price. They also can run much closer clearances,providing better ring seal and quieter operation.
Clevite makes a nice one piece balance shaft bearing ( no parting line groove). The PN is 1805M (1805M and SH-1429 S on the box).
I have run the Fellpro turbo head gasket with good results. Another favorite is the stock gasket from a Dodge dealer for a 2.6 for a Caravan. It's a graphite gasket that holds up very well. My current motor is 10 years old, so I don't know if they still carry the same part.
I did some checking on piston ring types. For the 2.6, Hastings and Sealed Power only make a chrome rings. That's the part the Randy ( AKA Dad) sells and uses on most of his rebuilds ( and what he recommends).
There is a Japanese (NPR) ring PN SWM31039 that has a molly faced compression ring. I have never tried it, but is seems like a decent part. All ring sets use chrome oil rings.
With a bit of basic block prep, either will work just fine. Ring manufacturing has progressed a lot in the past 20 years and getting rings to seat IMHO / experience is a lot less of an issue. That includes engines that I have done simple freshen ups on with a de-glazing hone.
Basically, moly is generally better, chrome works really well and is much easier to source.
That experience includes the following donts:
Don't use gapless rings ( AKA TS).
Run the second ring gap to the wide side. That allows for a better pressure differential across the top ring. Personal testing and research by Ford has proven that this is effective.
Don't use a grooved balance shaft bearings.
Don't try and reto fit your stock cam with roller rockers. I have a lot of data on this.... Short answer is its the wrong approach.
Balance shafts work and make a nice difference in how smooth the motor is. I run them, others seem OK without them. No problems in ten years. If you good oil pressure, the balance shafts will live forever.
The stock style cast aluminum oil pump is the best and any cast iron aftermarket pump is a downgrade.
Read the TSB on the oil pump drive chain. Torque values changed. They may have changed on the head gaskets as well.
Be careful of what pistons you choose. One manf has (used to have) a universal set of pistons that they list for turbo and non turbo. The turbo motor has a stock 7 to 1 CR. The universal pistons are "decked" to allow for milled heads (pretty common on rebuilds). With a lightly cut head you end up with a 6.5 to 1 compression ratio! If memory serves me right, with some combinations of parts, 6 to 1 was possible.
IF you end up with those, the motor will seem a bit doggy, slightly harder to start and you will get some low number like 120 psi when you run a compression test.
Most aftermarket pistons are decked about 1/2 CR point. For a non turbo motor, try and shoot for a minimum CR of 8 to 1.
I have run ACL pistons. Very light, short skirt nice design. They are a bit more prone to slap when cold, overall a nice part. Not sure if they are still available. Sealed power is another good choice, they are typically a hyperutetic alloy.
Get a fresh set of stock head bolts, skip the ARP studs. Use a thread cleaning tap on all the bolt holes.
Crack check the deck of the block. A hard overheat can (often) crack the block around the exhaust bolts holes. That can result in a motor that always loses head gaskets for no obvious reason. The hard overheat is a reason to stick with stock bolts. The stock bolts will yield and reduce the chance of a cracked block, the ARP's will generate a lot more force before they yield.
I run ARP studs on my turbo motor, they do work but stock is fine for almost any build.
A light cut to the deck is cheap insurance that you have a good gasket surface. Also check your cylinder bores for pitting. Motors that have lost a head gasket and then sat, often have badly pitted bores.
Main Bearings:
I have run aluminum bearing and tri metals. Both give good service. The tri-metals a a bit more forgiving to dirt in the motor during assembly. Either works just fine. ACL makes a nice aluminum bearing set.
Its been a while since I have done a 2.6, so I don't have the all the PN's handy. In general; the closer to stock, the better.
Also, make sure your distributor is working correctly. The grease in mechanical advance mechanism hardens and you don't get a smooth mechanical advance. The vacuum diagram seems to hold up, but should be checked.
On my turbo 2.6, the mechanical advance had ovaled out when it had advanced to the cruise RPM position. The motor ran hot, chugged fuel and had poor power.
In short... Before you start your motor, make sure the carb and dist are good (same with the cooling system).
You should be able to source all your parts yourself for not too much money.
Re: Best brand rebuild kit 2.6 [Re: Kevin C] #1072655 06/29/14 10:42 PM
ACL makes a nice piston. Never had any problem with them in anything.
heavy ditto on the dizzy mech advance. You can see it with a timing light. Rev the motor to 3000ish and with a worn advance mechanism, you can see the spark scattering all over the place. You can also see sticky advance and vac advance by using the light and alternately slowly and quickly revving the motor.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6519 MB (Peak: 0.7852 MB) Data Comp: Off Server Time: 2026-06-07 09:11:45 UTC
