1990 gen1 Tach Needle jumping #1072680 06/27/14 03:21 AM
crazyhal Offline OP
when i turn ignition switch to run my tach needle jumps and there are clicking sounds coming from pass side kick panel. fuel pump also runs without cranking. sometimes when i crank over engine tach needle no move and truck wont start.
1990 SWB 3.0
Re: 1990 gen1 Tach Needle jumping [Re: crazyhal] #1072681 06/27/14 06:03 AM
sounds like the control relay is going bad. Fuel pump should do a short run at switch on, then stop. Should run at all times while cranking. runs under ecu conrol in ign run as long as ecu sees spark.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5880 MB (Peak: 0.6360 MB) Data Comp: Off Server Time: 2026-07-16 03:26:42 UTC
