Re: 94 montero sr does not like water... gets shaky [Re: TOASTY] #1072858 07/07/14 03:51 AM
cap510 Offline OP
Nice pic mudraider!
Thanks Toasty!
Gonna try the grease and see what happens!
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: 94 montero sr does not like water... gets shaky [Re: cap510] #1072859 07/07/14 08:44 PM
Carlos, try WD40 to displace/get rid of any water. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 94 montero sr does not like water... gets shaky [Re: off-roader] #1072860 07/08/14 08:04 AM
justice Offline
Like ray said, WD40. Use dialectric grease on all connectors and connections to keep water out. Also just do your best to keep the engine dry. run full skid plates.
Re: 94 montero sr does not like water... gets shaky [Re: justice] #1072861 07/08/14 06:53 PM
PA_JERO Offline
Check your plug wires, coils and coil boots too. Claytk's truck didn't like the water the other day when we crossed the gila river. His sounded like it was missing pretty bad.
Re: 94 montero sr does not like water... gets shaky [Re: PA_JERO] #1072862 07/08/14 08:14 PM
cap510 Offline OP
Gonna try you guy's suggestions but the funny thing is that my black SR can be submerge and does not have this problem.
I like to pin point what can be causing the engine to behave like this... <img src="/forums/images/graemlins/confused.gif" alt="" />
I ordered the dialectric, should be here tomorrow.
Riding on 37" MTRs
Re: 94 montero sr does not like water... gets shaky [Re: cap510] #1072863 07/08/14 08:49 PM
cheesegrater Offline
The spark plug wires on your two vehicles are probably different or the wire end boots may be deteriorated on the one and not the other.
Re: 94 montero sr does not like water... gets shaky [Re: cheesegrater] #1072864 07/08/14 10:14 PM
justice Offline
^This^ Also once you do this..I've found that during wet misfires the electricity seeks out the path of least resistace to ground and leaves a carbon trail behind. This will cause the problem to repeat itself even after dry sometimes as the carbon trail creates a likely path to ground.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6247 MB (Peak: 0.7187 MB) Data Comp: Off Server Time: 2026-05-29 17:26:22 UTC
