Re: 94 montero sr does not like water... gets shaky
[Re: TOASTY]
#1072858
07/07/14 03:51 AM
Nice pic mudraider!
Thanks Toasty!
Gonna try the grease and see what happens!
[b]94/95 Montero SR "rockcrawler" Riding on 37" MTRs
[Re: cap510]
#1072859
07/07/14 08:44 PM
Carlos, try WD40 to displace/get rid of any water. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#1072860
07/08/14 08:04 AM
Like ray said, WD40. Use dialectric grease on all connectors and connections to keep water out. Also just do your best to keep the engine dry. run full skid plates.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#1072861
07/08/14 06:53 PM
Check your plug wires, coils and coil boots too. Claytk's truck didn't like the water the other day when we crossed the gila river. His sounded like it was missing pretty bad.
[Re: PA_JERO]
#1072862
07/08/14 08:14 PM
Gonna try you guy's suggestions but the funny thing is that my black SR can be submerge and does not have this problem.
I like to pin point what can be causing the engine to behave like this... <img src="/forums/images/graemlins/confused.gif" alt="" />
I ordered the dialectric, should be here tomorrow.
[Re: cap510]
#1072863
07/08/14 08:49 PM
The spark plug wires on your two vehicles are probably different or the wire end boots may be deteriorated on the one and not the other.
[Re: cheesegrater]
#1072864
07/08/14 10:14 PM
^This^ Also once you do this..I've found that during wet misfires the electricity seeks out the path of least resistace to ground and leaves a carbon trail behind. This will cause the problem to repeat itself even after dry sometimes as the carbon trail creates a likely path to ground.
