2.6 CAM Test #1072876 07/06/14 05:51 PM
Kevin C Offline OP
FYI, CAM test comparing valve lift VS rotation of three cams. the graph shows lift VS rotation for a stock cam with stock slipper rockers, the AU roller cam with its stock roller rockers and a stock slipper cam using the V6 Roller rockers.
I took this data a long long time ago... I figured It would be nice to share it again since this subject never seems to die.
1: The V6 rollers on the stock slipper 2.6 cam have a very lazy opening and closing ramp rate, lots of added duration with very little valve lift ( at the opening point).
2: With the V6 rockers, the intake valve opens really early. I centered all the profiles at the 180 mark ( or close to it). When installed on the engines the intake opens even sooner.
3: With the V6 Rockers, you lose almost all overlap.
Basically, you get a lot more duration but you don't get the benefit of good valve acceleration off of the seat that a properly design cam would get you.
It will work, but not nearly as well as a properly deigned cam.
Re: 2.6 CAM Test [Re: Kevin C] #1072877 07/06/14 06:55 PM
Malykaii Offline
Ma y I repost this on the starquest forums next time it comes up? With your credit of course.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: 2.6 CAM Test [Re: Malykaii] #1072878 07/06/14 07:38 PM
Kevin C Offline OP
Not a problem... That was where I posted it about 7 years ago. A reminder is always good.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.5962 MB (Peak: 0.6661 MB) Data Comp: Off Server Time: 2026-06-07 04:48:22 UTC
