Re: i want to change my lca bushing [Re: Malykaii] #1072910 07/10/14 07:23 AM
1
1morebike Offline OP
alright I'm ordering the acdelco ones soon. I'm worried about the camber as I'm not cranking the t bars because I'm happy with height for now. any advice would be cool
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: i want to change my lca bushing [Re: 1morebike] #1072911 07/10/14 03:30 PM
Malykaii Offline
See the 8th post... its mostly there.
Since your probably getting "made in china with proud" keep an eye on the ball joints and locktite those bushing bolts. Since your not cranking the springs up, I'm going to guess that you don't need longer bolts, but if you do, grade8 or metric10.8? only. Alignment is a must, and make sure you actually go to a place that will be willing to mess with camber/caster as alot of places only want to set toe and send you on your way as fast as possible.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: i want to change my lca bushing [Re: Malykaii] #1072912 07/11/14 02:09 AM
1
cool thanks. ill look for good front end alignment place. ill post up once it s done. thanks for all the help
Re: i want to change my lca bushing [Re: 1morebike] #1072913 07/11/14 06:00 PM
heathdogg Offline
I had the bolts on my UCA conversion come loose twice. After that I changed the bolt setup. I had coil-over shocks on the front which mad it impossible to retighten without removing the shock. I went with Socket cap bolts and the metal crimp locknuts. Didn't have any problems after that and the alignment guy was happier when he aligned it again. Pics are up here somewhare. Search by my handle if you are curious.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6076 MB (Peak: 0.6798 MB) Data Comp: Off Server Time: 2026-07-09 18:35:07 UTC
