Wobble over 55 after tire rotation #1072992 07/13/14 07:55 PM
hacker Offline OP
Did a straight front to back tire rotation on the 96' XJ and the first time I'm up to 55 I get a fairly serious wobble that judging by it's frequency is almost definitely coming from one of the wheels. Is there any other possible explanation for this other than that one of the wheels is probably not centered exactly square on the lugs?
~~_/) ~~
www.maps.org
Re: Wobble over 55 after tire rotation [Re: hacker] #1072993 07/13/14 08:20 PM
DRX350 Offline
If they didn't clean the wheel before attaching the weights, sometimes they fly off.
Or they just balanced the wheel wrong...
"Does this part need to be in there?"
1996 Dodge 1500 single cab / short bed, 5.9 4x4; 2" lift (springs not blocks), C.A.I and more mods to come.
Re: Wobble over 55 after tire rotation [Re: hacker] #1072994 07/16/14 05:19 PM
4x4Wire Offline
I am assuming the wobble was not present prior to the tire rotation?
The wobbly is generally tire related; wheel weights, chunks of rubber missing, bent rims, or slipped steel belt are primary issues.
Being not "square on the lugs" is possible but you would have loose lug nuts or, the mating surface between the rim and axle could have something that would not allow the wheel and axle to mate correctly.
In my experience, missing wheel weights or slipped steel belt are the most likely issues for wobble/ vibration at highway speed.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5926 MB (Peak: 0.6456 MB) Data Comp: Off Server Time: 2026-10-21 19:15:49 UTC
