how many bushings for rear control arm 1990 lwb #1072995 07/14/14 03:46 AM
1
1morebike Offline OP
after the fronts I'm doing the rears ome parts is confusing to me. it looks like i need three bushing per side and they are all the same bushing maybe
http://www.oemmitsubishiparts.com/parts/...iagramCallOut=4
its docent seem to make sense. anyone replaced these and if so where did you get the bushing.
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: how many bushings for rear control arm 1990 lwb [Re: 1morebike] #1072996 07/14/14 03:53 AM
4 total in the control arms
2 total in the track bar
2 for the sway bar
2 links for the sway bar
Re: how many bushings for rear control arm 1990 lwb [Re: rxinhed] #1072997 07/14/14 05:09 AM
1
2 for the sway bar
you sure looking at the diagram it looks like two in the rear of each arm and one in the front put they all seem to have the same part number.
Re: how many bushings for rear control arm 1990 lwb [Re: 1morebike] #1072998 07/14/14 08:55 PM
...and Ford style bushings on the front of the arms, 2 pieces each side. The circular bushings in the rear of the trailing arm are the same.
Re: how many bushings for rear control arm 1990 lwb [Re: rxinhed] #1072999 07/15/14 02:05 AM
Just to be clear, there are four bushings total for each rear trailing arm, two go in the front: MB809388, total of four required per Montero, and two go in the rear: MR112891, total of four required per Montero. The rear ones have to be pressed in/out.
Re: how many bushings for rear control arm 1990 lwb [Re: JohnnyBfromPeoria] #1073000 07/15/14 04:43 AM
1
thats what i was looking for, so 8 total
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6111 MB (Peak: 0.6814 MB) Data Comp: Off Server Time: 2026-07-09 18:33:23 UTC
