What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP #1073128 07/18/14 08:53 PM
tyty Offline OP
What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP?
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP [Re: tyty] #1073129 07/18/14 09:01 PM
JoeBurt Offline
12v to 24v and different ignition systems.
http://en.wikipedia.org/wiki/Mitsubishi_Pajero
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP [Re: tyty] #1073130 07/18/14 09:50 PM
haztoys Offline
Most everything...
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP [Re: tyty] #1073131 07/19/14 04:12 AM
90-91 are about the same although there may have been some minor tweaks.
Haven't looked at the later engines since I was always after the 3.5L in the gen 2's.
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP [Re: JoeBurt] #1073132 07/19/14 04:34 AM
tyty Offline OP
1994 3.0 did get this yet came in 1996 I think
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP [Re: off-roader] #1073133 07/19/14 05:45 AM
tyty Offline OP
Just trying to get more power out of Phi's gen 1
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP [Re: tyty] #1073134 07/21/14 07:39 PM
Jay Ayala Offline
Here is a picture of both blocks side by side.
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP [Re: Jay Ayala] #1073135 07/22/14 04:59 PM
tyty Offline OP
just try to get the 1990 up to 151 HP from 143 HP
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP [Re: tyty] #1073136 07/22/14 07:55 PM
JoeBurt Offline
Usually horsepower changes like this are from better castings on intake manifolds, larger port sizes, maybe slightly different ignition/ fuel maps. Maybe different grade of fuel used for testing. I would look at upping torque more than horsepower.
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP [Re: JoeBurt] #1073137 07/24/14 05:55 AM
Kevin C Offline
web page
A discussion about the 3.0 from a long time ago.
My take... Later years had small improvements in the intake and fuel injection system.
Engine Manual
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6356 MB (Peak: 0.7588 MB) Data Comp: Off Server Time: 2026-06-07 04:51:26 UTC
