what montero sport parts fit mighty max? #1073203 07/22/14 06:03 AM
boostin Offline OP
hey guys
up here in canada we have virtually no pre 2003 mitsus so pick n pull finds are rare.
i see our local yard has a 1997 montero sport and wonder what would fit my 89 mighty max??
kinda interested in suspension parts..
front springs?
rear springs??
rear diff?
front control arms?
thanks guys
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD!
1989 Mighty Max 2WD 2.6 5 speed slammed
1993 Eagle Talon TSI
Re: what montero sport parts fit mighty max? [Re: boostin] #1073204 07/22/14 06:18 AM
Jeep2Montero Offline
Your best bet is to get on rockauto.com and compare part numbers for the same parts on each vehicle.
Epxo rig-98 Montero "SR" with ARB front bumper and 33x9.50's
Trail rig-97 ZJ V8 with long arms and 35's, trailer queen
Re: what montero sport parts fit mighty max? [Re: boostin] #1073205 07/22/14 11:34 AM
Is it a leaf spring Sport? The axle should work. The brakes on the front should bolt on. Why don'tyou have early trucks up there?
Re: what montero sport parts fit mighty max? [Re: Mudraider] #1073206 07/22/14 04:17 PM
All of the above will fit except maybe the torsion bars, check them with your tape measure and see if the length is correct before buying them. The front diff may need it's own crossmember or a bracket made for it's mount but other than that you should be good.
Re: what montero sport parts fit mighty max? [Re: TOASTY] #1073207 07/23/14 01:46 AM
boostin Offline OP
That truck was pretty picked but wondering if the rear leafs would fit..it actually old man emu leafs.
I grabbed the calipers..do I need the master when switching to 2 piston calipers?
Re: what montero sport parts fit mighty max? [Re: boostin] #1073208 07/23/14 01:52 AM
No. Get the rotors and backing plates too.
Re: what montero sport parts fit mighty max? [Re: Mudraider] #1073209 07/23/14 02:59 AM
i put Montero sport leaves on my Gen 1.
Re: what montero sport parts fit mighty max? [Re: TOASTY] #1073210 07/23/14 03:44 AM
JARED Offline
Curious; What were the differences (if any) between the sport and gen1 rear springs? Rate, length?
Gone: '88 2.6 SWB ; '87 2.6 SWB
Current: '90 SWB V6 5Spd
Re: what montero sport parts fit mighty max? [Re: JARED] #1073211 07/23/14 04:32 AM
Military wrap so they are probably a little firmer because of that.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6282 MB (Peak: 0.7146 MB) Data Comp: Off Server Time: 2026-06-07 11:36:15 UTC
