1990 LWB rear bearings and outer seals, BROKEN* UPDATE* #1073439 08/05/14 04:22 PM
JAVYPRO Offline OP
Hey all,
I will make it quick.
About a month ago decided I had enough of the leaking gear oil into the rear brakes due to bad outer seals.
Had a machine shop press new bearings with the new outer seal. I installed a new inner seal and fresh lubricants.
Now, yesterday driving home I notice a grinding noise as if the bearings are dry or even worst gone bad. Could it be that the machine shop did not set them as far as they were supposed to and when I assembled it back together the extra pressure has mess up the bearings? That is one of my theories. Oil level is good after 2.5 qts and the finger tip measuring method, you know.
I will be taking apart in a few minutes, AGAIN.
Not difficult but. I was expecting not to touch it again in 25 years. <img src="/forums/images/graemlins/smile.gif" alt="" />
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: 1990 LWB rear bearings and outer seals, NOT *UPDATE* [Re: JAVYPRO] #1073440 08/05/14 06:53 PM
JAVYPRO Offline OP
After close examination my problem were the front brakes. I guess I got home so tired that I jumped the gun and misdiagnosed.
This morning, after my post, I pulled out of the garage and as I applied the breaks the noise went away but returned when released and the same when repeated the scenario.
So y'all., the problem were the front brakes. I will post before and after pics of when I replaced the bearings the first time.
Javy
Re: 1990 LWB rear bearings and outer seals, BROKEN *UPDATE* [Re: JAVYPRO] #1073441 08/09/14 02:07 AM
JAVYPRO Offline OP
<img src="/forums/images/graemlins/evil.gif" alt="" /> Guys, the bearings are bad. Drove it today and noise came back and smoke was coming out of the driver side of the axle. <img src="/forums/images/graemlins/evil.gif" alt="" />
Was it likely that the machine shop did not set them correctly?
I think that was the case <img src="/forums/images/graemlins/evil.gif" alt="" />
<img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/evil.gif" alt="" />
Javy
Re: 1990 LWB rear bearings and outer seals, BROKEN *UPDATE* [Re: JAVYPRO] #1073442 08/09/14 04:11 PM
Def report back what you discover... <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 1990 LWB rear bearings and outer seals, BROKEN *UPDATE* [Re: off-roader] #1073443 08/10/14 12:19 AM
Yeah, that makes absolutely no sense with new bearings why they would burn up. They get pressed down to a specific point, it's pretty much a no-brainier.
Re: 1990 LWB rear bearings and outer seals, BROKEN *UPDATE* [Re: JAVYPRO] #1073444 08/10/14 10:31 PM
JoeBurt Offline
Were the bearings greased before assembly? If gen 1 axles are like gen 2, no oil should get to the bearings. Strictly bearing grease. I just did the seals and bearings in my gen 2. Real pain! I used OEM Mitsubishi bearings which came pre-packed with grease.
Re: 1990 LWB rear bearings and outer seals, BROKEN *UPDATE* [Re: JoeBurt] #1073445 08/10/14 10:51 PM
Page 3-18 in the FSM shows bearing then seal from the inside to the outside. The axles that I have from the 4-cyl appear to be oil bath for the axle bearing, rather than grease.
Re: 1990 LWB rear bearings and outer seals, BROKEN *UPDATE* [Re: rxinhed] #1073446 08/19/14 03:40 PM
JAVYPRO Offline OP
Well, I assumed they were oil bath bearings but found on the MFS that they are supposed to be greased packed.
<img src="/forums/images/graemlins/scared.gif" alt="" />
The machine shop also said that I need the outer washer, on the outer side of the bearing. You know: seal/ washer/bearing/ washer/ lock washer and nut. That first washer is nowhere to be found, not in MFS neither on the ASA.
I believe that he is mistaking some parts.
I have attached the parts from MFS.
Heading to the machine shop, will keep you posted.
Javy
Re: 1990 LWB rear bearings and outer seals, BROKEN *UPDATE* [Re: Mudraider] #1073447 08/20/14 04:37 AM
haztoys Offline
In my world ..(declaimer) ... Its far from a 'no-brainer'..All Mitsu rear axles 'I've' been into witch is a lot of them are a 'tapered roller bearing center drive axles butting dropout unit".. The axles are not oiled by the hypoid gear oil ...They are grease packed as in the way the front wheel bearings are ... And do to the TRB on the axles they meet in the middle at the button block and are shimed for the right clearance at the outer alxe bearings ... If they are not shimed right they will cook or leak gear oil into the axle bearing...And do to them being a 'tapered roller bearing center drive axles butting dropout unit' they are a very strong unit...Last I check the 'ring' you could not buy .. The few axle bearing I have had to replace the bearing was crazy expensive and I had to machine up a new ring on my lathe...I would just get a used axle with a good bearing ..Re-grease it and shim it up and be done with it ...Its rare to kill a Mitsu axle bearing ...Now there maybe a Mitsu axle that I have not had my hands in thats not a TRB set up...And at one time there was a half a$$ after market ball bearing that was sold and did not work do to ball bearing cant take a side load..As in a Toyota axles that eat ball bearings like candy...
Captain Gear Box
Hazardous Toys inc
Re: 1990 LWB rear bearings and outer seals, BROKEN *UPDATE* [Re: haztoys] #1073448 08/20/14 05:26 PM
JAVYPRO Offline OP
So that ring or spacer between the bearing and the outer seal do exist? <img src="/forums/images/graemlins/scared.gif" alt="" /> Do you know the dimensions?
Javy
PHP: 7.4.33 Page Time: 0.012s Queries: 17 (0.009s) Memory: 0.6406 MB (Peak: 0.7830 MB) Data Comp: Off Server Time: 2026-07-15 02:06:16 UTC
