95 SR drivetrain into a gen 1? #1073452 08/06/14 03:19 AM
silveraider Offline OP
I found a 1995 SR with the 3.5 v6 air lockers, etc. I would love to swap everything I can into my gen 1 raider. Will the engine, trans and transfer case bolt in without much work? How about the front and rear axles? I would normally do a search but I need to know ASAP so I can scoop up the rig.
Thanks in advance.
Ed
Re: 95 SR drivetrain into a gen 1? [Re: silveraider] #1073453 08/06/14 03:42 AM
sasnydley Offline
Is your truck a V-6? 2dr or 4dr? I do know a lot of parts will "bolt in" Not sure if all will.
Re: 95 SR drivetrain into a gen 1? [Re: sasnydley] #1073454 08/06/14 03:47 AM
Whoops 2 door 2.6 4 cylinder.
Re: 95 SR drivetrain into a gen 1? [Re: silveraider] #1073455 08/06/14 03:54 AM
Lots and lots of work, being that it's a 2.6, leaf-sprung truck.
Re: 95 SR drivetrain into a gen 1? [Re: JohnnyBfromPeoria] #1073456 08/06/14 04:00 AM
I figured it would be a good amount of work. I really just want to do a motor swap. The 2.6 in anemic even with only 84k on it and in great running order.
Re: 95 SR drivetrain into a gen 1? [Re: silveraider] #1073457 08/06/14 05:26 AM
Yours an auto? If so, you'll need a V-6 auto bell housing to swap onto your KM-148. Mix up the mounts, get it all together, then weld the mounts back into position. The wiring harness. Yikes. That's where I'm at right now. 94SR into an 87. Overall a lot of work, but it will go with the AZ Crews assessment that it will be worth it.
Re: 95 SR drivetrain into a gen 1? [Re: Mudraider] #1073458 08/06/14 06:28 AM
It's way worth it, enough said. As for the rear axle swapping under leaf springs
Picture of my SR axle under leaf springs
Re: 95 SR drivetrain into a gen 1? [Re: TOASTY] #1073459 08/06/14 01:39 PM
Yep it's a auto and so is the donor rig. I'm going to check it all out tomorrow.
Thanks!
Re: 95 SR drivetrain into a gen 1? [Re: silveraider] #1073460 08/06/14 08:57 PM
And Toasty knows.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6268 MB (Peak: 0.7142 MB) Data Comp: Off Server Time: 2026-06-09 21:57:52 UTC
