95 Can't open rear hatch
#1073588
08/09/14 05:59 PM
Can't get in the rear hatch. The handle just acts as if it is locked all the time. Even tried the inside handle. Is there a way to take off the inside panel to get access without opening the door? Thanks!
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around 95 LS-- Dual Bouncy Seats 234k and still rockin'
Re: 95 Can't open rear hatch
[Re: brubren3815]
#1073589
08/16/14 05:49 PM
Trying a different approach... Is there any way to open the back hatch if both handles do not work?
[Re: brubren3815]
#1073590
08/17/14 02:53 AM
The outside latch on mine broke about9 months ago. The inside still opened with a bit of work.
Try removing the door mounted tool kit and the inside latch surround. You may be able to pop off the door panel. You can then slit the plastic behind the door panel. This should give you access to the latch assembly and linkage.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5963 MB (Peak: 0.6493 MB) Data Comp: Off Server Time: 2026-06-07 09:11:44 UTCValid HTML 5 and Valid CSS
