1990 blew crank seal- I think- Pic of the loaded beast
#1073682
08/14/14 05:02 AM
Well I sold the 1995 SR- I have decided I never want to deal with a 6g74 motor with all it's issues. Well I took my daughter to Orlando (UCF)yesterday. I ended up going through about 12 quarts of oil before getting home. Tonight started to tear down the front. Seems to be crank seal- I still have to remove a couple of the little bolts that hold the cover and the crank bolt. LOL we had the truck packed to the roof. Plus the giant bean bag on the roof.
Re: 1990 blew crank seal- I think- Pic of the loaded beast
[Re: sasnydley]
#1073683
08/14/14 11:55 PM
I'm sure it was just the seal that took a crap on you but maybe do a compression test just to make sure your rings are ok. Blown seal could be do to High crank case pressure.
89 2 dr turbo diesel 89/88 "Backwoods sas"
[Re: lordtrunks]
#1073684
08/15/14 01:56 PM
I'm sure it was just the seal that took a crap on you but maybe do a compression test just to make sure your rings are ok. Blown seal could be do to High crank case pressure. With over 300000 mile on it and was driving 80mph I am sure there was some pressure. Plus this is the truck that broke it's crank bolt and may have some chewing/groves on crank. Was the crank seal.
[Re: sasnydley]
#1073685
08/17/14 03:16 AM
Truck is all back together with all new seals and T-belt. Seems to be OK.
[Re: sasnydley]
#1073686
08/17/14 04:07 AM
[Re: lordtrunks]
#1073687
08/30/14 05:14 PM
In my experience the good thing about a front crank seal leak is that it makes the crank pulley easy to get off. <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6143 MB (Peak: 0.6843 MB) Data Comp: Off Server Time: 2026-05-29 22:37:11 UTCValid HTML 5 and Valid CSS
