Page 2 of 3 1 2 3
Re: bought 89 v6 raider. drove thru puudle. now no start. [Re: haztoys] #1073840 08/24/14 04:23 AM
METALMOVER Offline
I agree with the starting fluid, and how big was the puddle??? 6 beers in... MM
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: bought 89 v6 raider. drove thru puudle. now no start. [Re: fasteddy] #1073841 08/24/14 10:35 AM
lordtrunks Offline
89 2 dr turbo diesel
89/88 "Backwoods sas"
: bought 89 v6 raider. drove thru puudle. now no start. [Re: lordtrunks] #1073842 08/29/14 08:50 PM
tbonesdam Offline OP
Well, I finally had an assistant available today to help me check for spark or fuel. It looks like no spark is coming from the coil. Maybe I should start replacing things like the coil and fuel filter. Gas looked good from tank. Inhibitor switch below auto shaft looks like it has been bypassed although connections looked good. any suggestions?
SELF MADE CHOP TOP W/HARD TOP.87 5 speed 2.6 less Balance shafts.Raider 88 Rust-O-loomed Body.Herculined Interior.Rust-proofed Frame.(Eastwood Stuff)Prothane Bushings.33x12.50.3in. Body Lift.2in. SHackle Lift + Torsion Crank.
89 Dodge Raider V6 Auto
90 Mitsu Montero LS so Clean!
Re: : bought 89 v6 raider. drove thru puudle. now no start. [Re: tbonesdam] #1073843 08/29/14 10:13 PM
I also have an 89 V6 Raider, and had a similar issue. Total brain fart right now (horrible day at work), but this little gems wiring connectors was fighting me tooth and nail, but I figured out the connector was the issue. It is the part right by the coil, on the same bracket.
Re: : bought 89 v6 raider. drove thru puudle. now no start. [Re: Mudraider] #1073844 08/30/14 12:38 AM
Wait a minute. You had spark after the no start, and now you don't? I'd download the 89 powertrain diagnostics manual from mitsubishilinks.com and do all the spark related tests with a VOM.
Re: : bought 89 v6 raider. drove thru puudle. now no start. [Re: fasteddy] #1073845 08/30/14 01:18 AM
Eddy, some PO/and/or mechanic had put some kinda connectors in the stock fitting, I had no problems with it for the longest time, then it would intermittently shut off. Sometimes it would start back up immediately , checking spark would just frustrate me, it would have it sometimes, others, not so much. Checking continuity with it disconnected was pointless, the tension was allowing it to connect. The mitsubishilinks manual is prolly going to be the fastest way to figure it out. Unless you just happen to get dumb lucky.
Re: : bought 89 v6 raider. drove thru puudle. now no start. [Re: Mudraider] #1073846 09/04/14 01:22 AM
Hello All I was able to go through the coil to find it was getting juice but not sending spark. I should have a fresh coil in my mailbox tomorrow. I sure hope this gets this baby back on the road. The canyon we recently moved to is eating our vehicles up!
Cheers!
Re: : bought 89 v6 raider. drove thru puudle. now no start. [Re: tbonesdam] #1073847 09/07/14 04:53 PM
Well I put new ignition coil in and she started up first try. Ran for just a few seconds than poof. No restart. I checked coil again and no spark. I am going to try and figure out how to read codes because the engine LIGHT was on. Anybody have any tips on reading codes? Cheers!
Re: : bought 89 v6 raider. drove thru puudle. now no start. [Re: tbonesdam] #1073848 09/07/14 06:28 PM
Diagnostic plug is above glove box, to the rightish, taped to the harness.
Using upper right and lower left terminals, catch up, connect a test light or analog votmeter and with the switch in on, read the pulses, long and short. Long is tens, and short is units. Long, short, short, short is 13. In the fsm mpi section is the chart of codes.
Re: : bought 89 v6 raider. drove thru puudle. now no start. [Re: fasteddy] #1073849 09/08/14 12:42 AM
That was easier than I thought. I tried to use a multi meter but numbers were jumping around so much I thought "no way". Than after using a analog reader it was easy to figure out. Looks like my tps and injector codes came up. I guess I'll order a new tps and try to clean the connections! They looked really oxidized! Cheers
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6424 MB (Peak: 0.7671 MB) Data Comp: Off Server Time: 2026-10-24 23:54:58 UTC
