Page 2 of 4 1 2 3 4
Re: I need a distributor plug [Re: haztoys] #1073929 10/07/14 04:27 PM
crazyhal Offline OP
Did you get new plugs...?
no not yet. i have jumper wire on bad terminal.
1990 SWB 3.0
Re: I need a distributor plug [Re: crazyhal] #1073930 10/08/14 01:22 PM
haztoys Offline
Your speaking of the plug at the dist...You have a 90 ..Right...???
The plug at the dist has no lead...Right ...???
It plugs right into the dist...That plug is what you want...?
Whats your mailing address..?
Re: I need a distributor plug [Re: haztoys] #1073931 10/08/14 07:58 PM
crazyhal Offline OP
ill try to post picture
1990 SWB 3.0
Re: I need a distributor plug [Re: crazyhal] #1073932 10/09/14 05:46 PM
crazyhal Offline OP
yea 1990 5 speed.
1990 SWB 3.0
Re: I need a distributor plug [Re: crazyhal] #1073933 10/10/14 01:31 AM
Attachment won't work for me
Re: I need a distributor plug [Re: crazyhal] #1073934 10/11/14 01:35 AM
haztoys Offline
I cant see pic's either ..?
Do to time in my world I cant wate on pic's .... Not really sure what you need or if you have a 89 or 90 year monty ... I am mailing you a mess of parts ...Use what you need ...Mail the left over back an pay me for what you use...
Please dont screw me on this ...
Captain Gear Box
Hazardous Toys inc
Re: I need a distributor plug [Re: haztoys] #1073935 10/11/14 11:03 PM
haztoys Offline
This is my karma test of the good or bad in this world we live in ...
I mailed out a box of parts to you ...Hope it is what you need ... Please mail back what you dont uses ...
Anyone want to test a dist from a 90 car on there 90 to 92 montero for me ...???? .... Just thinking it may work on the trucks ...
Re: I need a distributor plug [Re: haztoys] #1073936 10/14/14 06:05 AM
KrzyDav Offline
I was thinking he had an '89. One thing I just discovered is that if you try to unplug the rubber plug going into the bottom of the '89 dizzy, you can crack these skinney old brittle alignment pins off the module in the dizzy. That can give you "bad sensor codes"...
The '89 module is available (rockauto is soldout) part number is like,,,Standard LX122.
I have a '89 firewall plug that can be soldered on(the rubber dizzy end is toast).
dave h.
Re: I need a distributor plug [Re: KrzyDav] #1073937 10/16/14 05:43 AM
haztoys Offline
Not sure what year he has ... Now there is said to be 90 SWB's out there ... Now is the SWB 90 have 89 elec's or 90 elec's ....?
Re: I need a distributor plug [Re: haztoys] #1073938 10/19/14 04:56 PM
crazyhal Offline OP
i have 1990 SWB non EGR. my 1989 had 2 wire plug at dist and 1990 has 4. i used 4 wire plug and will send stuff i didn't need back next week. Thanks so much!!!
My ECM not receiving crank signal from crank angle sensor to fire coil. checked distributor with LED and cam and crank both working but pulling codes show bad crankshaft angle sensor.I have a 1 year old rebuilt ECM from ECM in texas. should i check continuity from power transistor to ECM? i have been messing with this for 3 months.
1990 SWB 3.0
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 17 (0.009s) Memory: 0.6376 MB (Peak: 0.7777 MB) Data Comp: Off Server Time: 2026-07-15 09:03:37 UTC
