Gas Tank Lift
#1073970
08/27/14 04:49 PM
I feel I recall reading a write up on a gas tank lift for a gen1 2.6. It must have been over a year ago... and now that the time has come, I cant find any info on the topic. Does any of this sound familiar to anyone? Thanks.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: Gas Tank Lift
[Re: Malykaii]
#1073971
08/27/14 08:41 PM
Not on a 2.6. The fear of cutting the frame because the springs putting tension on the frame. If the Shogun would of stayed here, I was going to do it to that.
Re: Gas Tank Lift
[Re: Mudraider]
#1073972
08/28/14 03:51 PM
So the concern is that if I cut the frame cross members, the leaf springs will cause the frame rails to shift? Got that right?
So normally I do everything myself, besides welding. Hence a 4x4 fab shop will take this on. I was just hoping to see more info to maybe even send to the shop.
What I see is the gas tank bolts to two cross members. The rear one is pretty large and looks as if its the one that holds the frame together. The front one is wimpy in comparison and looks to only exist to hold the gas tank, not provide any support. Plus that one is so rusted out (I dont know how the tank still stays up) that the frame would have shifted already had it relied on the cross member for suport.
Best I got is cut out front cross member, move gas tank forward an inch and up three ish. Bolt the rear of tank to side rather than bottom of cross member. Then weld in a new tube as a front cross member.
No one else did this before? I refuse to believe everyone goes wheel in with the tank a foot bellow everything else. Thanks!
Re: Gas Tank Lift
[Re: Malykaii]
#1073973
08/29/14 11:08 PM
I take it you saw the ones for the coil spring set-up? I wondered why that wouldn't work, and that is what I was told. Now having been involved in quite a few V-8 S-10 conversions with rear 4 link conversion set ups, and a couple of Mustang IFS conversions, that makes no sense to me. You would have to lower your rear spring hangar whatever the distance is of the body lift spacers, but that seems very do-able. My .02.
