Which ACT clutch? #1074031 08/31/14 01:17 PM
promodmerc Offline OP
I could have sworn there was a thread here regarding which ACT clutch & pressure plate is best but after a lengthy search I didn't find it.
Re: Which ACT clutch? [Re: promodmerc] #1074032 08/31/14 09:53 PM
DRX350 Offline
Must have been erased. I did a search and came up with nothing as well...
But, on the innertubes (net) I found this;
ACT clutch kit for sporty
"Does this part need to be in there?"
1996 Dodge 1500 single cab / short bed, 5.9 4x4; 2" lift (springs not blocks), C.A.I and more mods to come.
Re: Which ACT clutch? [Re: DRX350] #1074033 09/02/14 11:01 AM
Everet Offline
Hey Guys,
I ordered a clutch from SOUTHBEND CLUTCH and the pressure plate gave a much heavier pedal than stock and had it come with a kevlar clutch. Well, I think the kevlar doesn't like the slippage I have to do cause of my 32" tires so I am going back to a organic Exedy disc.
Hope this helps.
Everet
Re: Which ACT clutch? [Re: Everet] #1074034 09/02/14 07:29 PM
How much does the tranny/transfer case weigh? A friend of mine knows someone that might be able to help with replacing it but needs to know an idea of the weight.
I believe the ACT clutch I'm looking at is organic. A 235/75/15 or 30x9.50x15 is the largest tire I will be running.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6011 MB (Peak: 0.6573 MB) Data Comp: Off Server Time: 2026-06-07 04:47:54 UTC
