Re: neutral safety switch - see picture [Re: jwp] #1074062 09/04/14 03:31 AM
plh Offline
I don't have a wiring diagram but if anyone does, it would be appreciated. Haynes is missing the starter diagram from the manual.
http://www.mitsubishilinks.com
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: neutral safety switch - see picture [Re: plh] #1074063 09/04/14 03:55 AM
jwp Offline OP
Wow, that is a good link, thanks! Funny, doesn't show the '91. The 1989 shows a simple two-pole inhibitor switch instead of a mode-switch with poles for all the gears. I will check out the 1992. I finally got the thing running by cleaning the switch out with alcohol REALLY well and taping it in place in the neutral position. It starts. FWIW, it seems to work better with a full charge batt. It may be a little precarious but it should run until Friday when my switch arrives from NAPA. Thanks for the help guys.
1991 LWB Montero LS 213kmi - original. Stock.
2003 LWB Montero LTD 95kmi - original. All leather, stock and sweet
----Drive it like you have to use it to get to work in the morning.----
Re: neutral safety switch - see picture [Re: plh] #1074064 09/04/14 03:56 AM
black/yellow to same...
Re: neutral safety switch - see picture [Re: jwp] #1074065 09/04/14 02:11 PM
sasnydley Offline
My truck (90) which is the same as yours had the wires going to the starter go bad in the harness. I did the Ford selinoid swap. If you search ford selinoid swap or something of the sort you may find it. May be your issue also.
Re: neutral safety switch - see picture [Re: sasnydley] #1074066 09/11/14 06:21 PM
jwp Offline OP
Well, after replacing the neutral switch (shift position on the side of the shifter) and then the ignition switch (starting solenoid current runs through this), it turned out to be the bloody starter solenoid. Good job you guys that mentioned that first. IT'S ALIVE!! <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: neutral safety switch - see picture [Re: jwp] #1074067 09/12/14 11:41 PM
I won't do it. I'll restrain myself.
Wrong...
Nya nya nyanya nya, tojaso, tojaso, tojaso, I tell you three times... <img src="/forums/images/graemlins/evil.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.004s) Memory: 0.6178 MB (Peak: 0.7044 MB) Data Comp: Off Server Time: 2026-10-22 12:14:11 UTC
