I can rebuild your turbo. #1074084 09/03/14 01:37 AM
87monty Offline OP
Hi guys just wanted you to know I now rebuild turbos.
If you have a turbo that needs to be rebuilt Pm me for a quote.
All of my rebuilds come with a 1 year warranty and use only Oem or better quality parts.
I bought out my friends shop and I now have all the factory tooling to do an even better than before job.
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: I can rebuild your turbo. [Re: 87monty] #1074085 09/03/14 02:45 AM
Awesome! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: I can rebuild your turbo. [Re: TOASTY] #1074086 09/03/14 03:26 AM
Malykaii Offline
Can you do conversions like a 12a to 16g?
Also, post up on the starquest site. Tons of guys there who can benefit from your service. Heads up, they're a bunch of cheap mofos, so if your prices are right, they might bite.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: I can rebuild your turbo. [Re: Malykaii] #1074087 09/03/14 04:02 AM
87monty Offline OP
Thanks guys, I can do most factory rebuilds and upgrades onsite, if its super technical I have my resources.
My prices are less because I have no overhead based from my personal shop so you get the full benefit from that. I also will sale DIY intercooler tubing kits Silicone Couplers,blow off valves and intercoolers to boot.
96 SR
Re: I can rebuild your turbo. [Re: 87monty] #1074088 09/03/14 04:24 AM
Malykaii Offline
Intercooler piping? Any solutions for a starquest swapped gen1?
Re: I can rebuild your turbo. [Re: Malykaii] #1074089 09/03/14 05:37 AM
87monty Offline OP
I'm going to sale kits you can DIY plumbing for your turbo intercooler.
Its a kit that has all the bends and straight tube you need for a install.
Is your motor pretty much stock? Do you have a factory intercooler installed now? I have the star quest setup as well and I think a 14b turbo is a good upgrade
eclipse turbo). They offered a 14G turbo as a factory option which will make a noticeable difference either way over the stock 12b that most come with. I ran a 20g and didn't like the spool for our rig setup. The faster spool time the more usable power you have on tap. So bigger isn't always better. 14g-14b would be Max for a starion swap in a montero. We will never set land records nor would I want to in a 4000 plus lbs square box. <img src="/forums/images/graemlins/smile.gif" alt="" />
96 SR
Re: I can rebuild your turbo. [Re: 87monty] #1074090 09/03/14 07:16 AM
Kevin C Offline
web page
You might find a couple of photos of an intercooler and piping installed in a Gen 1 along with about 20 years of random Raider buildup pics.
Re: I can rebuild your turbo. [Re: Kevin C] #1074091 09/03/14 08:50 AM
mxmikie Offline
any turbo ??? how about a IHI RHB32 ??
Re: I can rebuild your turbo. [Re: mxmikie] #1074092 09/03/14 06:20 PM
87monty Offline OP
sure can, its the same turbo as the narrow
bearing Rhb31. Is there any physical Damage to the turbo?
96 SR
Re: I can rebuild your turbo. [Re: 87monty] #1074093 09/03/14 09:41 PM
Jason, I don't know if I'd do business with somebody who can't finish a 2.4 swap in over a year... <img src="/forums/images/graemlins/evil.gif" alt="" /> You need to update that post.
the 14b is a very nice upgrade. The 12a puts out about 365cfm at 15psi, and the 14b blows well over 450 at the same pressure. That means the 12a peaks out at about 240hp and the 14b at around 300+, using 1.5cfm/hp as a rule of thumb...
PHP: 7.4.33 Page Time: 0.006s Queries: 17 (0.004s) Memory: 0.6471 MB (Peak: 0.7828 MB) Data Comp: Off Server Time: 2026-05-29 19:54:51 UTC
