Replacing dodge raider wheel bearings #1074103 09/03/14 03:06 AM
mfarmer10 Offline OP
Hey all,
I see there is a thread on replacing wheel bearings on a gen 2 montero. Is it much different than the gen 1. I have an 89 raider v6. Is this a very difficult task? Any tips?
Thanks,
Mackinley
Re: Replacing dodge raider wheel bearings [Re: mfarmer10] #1074104 09/03/14 03:57 AM
Same same.
Re: Replacing dodge raider wheel bearings [Re: mfarmer10] #1074105 09/03/14 04:33 AM
Hey all,
Thanks,
Mackinley
Wear rubber gloves when packing the bearings. Messy job
Re: Replacing dodge raider wheel bearings [Re: Mudraider] #1074106 09/03/14 05:08 AM
Heck, wear a full Racal suit. I found bearing grease in the small of my back, under a shirt and tee shirt and hoody once. No idea how it got there.
Re: Replacing dodge raider wheel bearings [Re: fasteddy] #1074107 09/07/14 05:02 PM
I don't wear gloves when packing bearings. I've found that the grease does wonders for the hands. Kind of like soaking in Palmolive.
Re: Replacing dodge raider wheel bearings [Re: JohnnyBfromPeoria] #1074108 09/07/14 05:32 PM
It's the stuff in it with the distinctive smell of castor oil. Castor oil is a poison, and can absorb thru the skin. My father swore by castor based lubricants because the oil would hold up to higher temps, which explains my addiction to Castrol to this day. Besides, the hand cleaner that will remove all bearing grease has yet to be invented. Even Dawn doesn't work.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6125 MB (Peak: 0.6820 MB) Data Comp: Off Server Time: 2026-06-07 04:23:46 UTC
