97 4Runner Trans Shift Solenoid Location? #1074202 09/10/14 01:06 AM
brink Offline OP
Hello all. My 97 4runner with 150k miles just put out code po773. From what I have seen online it is the trans shift solenoid. Does anyone know if this is serviceable from outside the trans? If so where is it located on the trans?
About a year and a half ago the trans cooler in the radiator blew out and the shop flushed it several times with new radiator. It's been fine since and even runs and seems to shift ok with the check engine light on. I read that the s solenoid may need to be cleaned. Thanks in advance for any help!
Re: 97 4Runner Trans Shift Solenoid Location? [Re: brink] #1074203 09/16/14 08:40 PM
Dandeman Offline
Toyota Moderator
Not much detail, but the solenoids are removable by pulling the pan off and removing the 3 bolts as shown in the rather sketchy diagram..
A little more detail here in this diagram of the valve body....
Re: 97 4Runner Trans Shift Solenoid Location? [Re: Dandeman] #1074204 10/12/14 04:33 PM
brink Offline OP
Thank you for the diagram!
PHP: 7.4.33 Page Time: 5.398s Queries: 15 (0.005s) Memory: 0.5937 MB (Peak: 0.6475 MB) Data Comp: Off Server Time: 2026-10-24 03:23:55 UTC
