Page 2 of 4 1 2 3 4
Re: LED Light Bars [Re: off-roader] #1074315 10/26/14 08:11 PM
AZRaider Offline OP
Is the front lens glass or plastic? A good quality plastic that can handle impacts is preferred...
It's a good solid plastic
1987 Dodge Raider, 2.6L, manuel, bone stock with a whole lot of new and refurbished parts. Brought back from the dead after 12yrs.
Re: LED Light Bars [Re: AZRaider] #1074316 10/28/14 06:20 AM
AZRaider Offline OP
Here is it lit up.
Re: LED Light Bars [Re: AZRaider] #1074317 10/29/14 10:23 AM
Pete_D Offline
Looks pretty close to the Cree light bars I'm running on my ARB.....in front of the grill are/have two small 18W (36W total) that throw out a (surprisingly)good light by themselves....on each side have 108W (216W total) light bars below each headlight with 3 independent switches center/left/right.....I did have one 108W in the center but it blocked air flow so I went for the 2 smaller ones - grabbed another 108W putting one on each side.....happy with the look and the result.....had 2 KC 130W Daylighters before but like the smaller running drain/draw of the LED's......they also are flood/distance - one reason for going with 2 so I can aim one up if/as wanted/needed......the bracketing is different on mine and the LED bars run heavy....1st when on the center I mounted solid and it took 6 months to destroy the brackets....had new brackets fabricated and mounted by running larger bolts + cut sway bar link pin bushings in 1/2 using half over/half under the bumper with double nutted stainless bolts/washers.....holding well so far with no loosening or bracket metal fatigue.....tried to attach a pic but won't let me.....but the pics were in broad daylight and the lights over powered the camera.....
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: LED Light Bars [Re: Pete_D] #1074318 11/02/14 05:12 PM
87monty Offline
Do they sale them in a 18"?Im interested for sure <img src="/forums/images/graemlins/smile.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: LED Light Bars [Re: 87monty] #1074319 11/02/14 06:15 PM
AZRaider Offline OP
No, just the sizes I listed. Sorry
Re: LED Light Bars [Re: AZRaider] #1074320 11/02/14 09:04 PM
87monty Offline
Its cool so the price includes shipping? I like the 22" looks nice and brite.
96 SR
Re: LED Light Bars [Re: 87monty] #1074321 11/02/14 11:00 PM
AZRaider Offline OP
Yeah, just for those here on the Mitsu forum though. Usually would charge for it. And it is. That is actually the one you would be getting too. Was only out of the box and hooked up long enough to light it up, so 5 minutes at most
Re: LED Light Bars [Re: AZRaider] #1074322 11/03/14 01:51 AM
87monty Offline
Can you get me another if I want to run two up front?
96 SR
Re: LED Light Bars [Re: 87monty] #1074323 11/03/14 03:24 AM
AZRaider Offline OP
Easily. Just need a couple days
Re: LED Light Bars [Re: AZRaider] #1074324 11/04/14 02:55 AM
You don't have to ship them to me, just stop by. We may be thinking of one of the 22" or possibly larger. Will keep you posted.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6447 MB (Peak: 0.7711 MB) Data Comp: Off Server Time: 2026-05-29 17:25:52 UTC
