32 36 Weber mock up - Am I crazy? #1074341 09/15/14 12:19 AM
JARED Offline OP
Alright - Finally getting around to installing the Weber. Thank you to everyone on the board for your help thus far.
Am I seeing backwards...? The throttle linkage and fuel inlet seem to be oriented incorrectly. The throttle linkage should be on the back, with Choke facing driver fender, and fuel inlet should be on the front side of motor. It's as-if they assembled the top half of the carb opposite as intended (at least for this application)
Obviously when you rotate the carb. the linkage is working in reverse...Strange - Any ideas? I was going to contact Redline in the morning.
Gone: '88 2.6 SWB ; '87 2.6 SWB
Current: '90 SWB V6 5Spd
Re: 32 36 Weber mock up - Am I crazy? [Re: JARED] #1074342 09/15/14 12:44 AM
ryany Offline
Did the kit come with installation instructions? I would assume there would be something included with the kit to make the throttle cable work properly, as well as instructions on how to put it together.
95 Montero SR
Re: 32 36 Weber mock up - Am I crazy? [Re: ryany] #1074343 09/15/14 12:57 AM
JARED Offline OP
It does include instructions - Generic instructions, the install is very straight forward though.
It's not a problem really, I'm going to leave this as-is and just route the throttle linkage to work. I've seen a few Mazda B2600s with the carb oriented like this.
Re: 32 36 Weber mock up - Am I crazy? [Re: JARED] #1074344 09/15/14 01:45 AM
MartySoCal Offline
They do make 32-36 Weber carbs that are the mirror image, DGEV vs DFEV. Maybe check with the manufacturer of the kit to see if this is the correct setup.
http://www.redlineweber.com/html/Types/making_the_right_choice.htm
Redline Montero kits are sold both ways:
the K610 vs the K614
http://www.redlineweber.com/carb-kits/auto/mitsubishi/
The K614 DFEV kit for the auto trans probably has the linkage in the close to stock location.
Re: 32 36 Weber mock up - Am I crazy? [Re: MartySoCal] #1074345 09/15/14 03:17 AM
JARED Offline OP
Marty - That's exactly it, thanks for the information <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6088 MB (Peak: 0.6743 MB) Data Comp: Off Server Time: 2026-11-03 12:28:50 UTC
