Air Conditioning Compressor Signal #1074491 09/23/14 11:23 AM
Davey Offline OP
My air con compressor is not kicking in, specifically the a/c cut relay isn't receiving the signal to ground it's coil which then activates the compressor clutch.
Relays and fuses are all fine, a/c clutch activates when fed direct power, condensor fan runs, have also jumpered the a/c pressure switch. Still no luck as yet.
Apparently the ECM plays a part in a/c activation too.
Anyone got any tips/ideas?
Cheers
Dave
Long a$$ 2000 Sporty, auto, 5.38 gears, TF front locker, 4"+ front lift (Kings +40 springs, 50mm spacers, 1.5" diff drop), TJ 104 rears 3" + 50mm coil spacers, 1.5" body lift, 31/10.5r15's on 15x8 Kings (ET-13), WARN manuals, Smart Bar, spotties
Re: Air Conditioning Compressor Signal [Re: Davey] #1074492 12/16/14 12:39 PM
Davey Offline OP
Low pressure in system
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5858 MB (Peak: 0.6340 MB) Data Comp: Off Server Time: 2026-06-07 07:24:57 UTC
