Gen1 Interior Lights Died #1074506 09/26/14 03:55 PM
jonboyb Offline OP
Driving home last night all dash, gauge, heat/AC, etc lights died. Idiot lights, highbeam light, blinker lights, etc still fine. Search not working for me today so hopefully this is a simple fix. I'm guessing the rheostat is dead???
Something else?
1989 Nevada Sand Raider 2.6 5-speed
Turbo FI with Megasquirt
Re: Gen1 Interior Lights Died [Re: jonboyb] #1074507 09/26/14 04:20 PM
jonboyb Offline OP
Just did some diagnostics at lunch. Tails are also out and fuse blown. Replacing fuse blows as soon as lights are turned on. Headlights fine. Just what I wanted to do this weekend.....track a short.
Any advice on where to start?
Re: Gen1 Interior Lights Died [Re: jonboyb] #1074508 09/26/14 06:42 PM
Jay Ayala Offline
Someone on the forum was recently talking about solving their electrical short in a trailer wiring harness. As it turned out, somehow it was grounding on the exhaust pipe below the bumper.
Re: Gen1 Interior Lights Died [Re: Jay Ayala] #1074509 09/26/14 06:49 PM
jonboyb Offline OP
Not going to be the issue here, no trailer wiring or other errant hookups. I unhooked the dimmer switch, replaced the fuse 2, and all my nighttime exterior driving lights work fine. Dimmer switch checks out fine. I shorted the pigtail to the dimmer (basically 0 resistance = full brightness condition) and fuse blew instantly again. Something related to the dash lights is the culprit.
Re: Gen1 Interior Lights Died [Re: jonboyb] #1074510 09/26/14 10:01 PM
jonboyb Offline OP
Think I found it. Starting unplugging illumination harnesses that were easy to reach and plugging back in to see which took out the fuse. Tracked back to radio and found a scuff on the GW wire to dim radio with lights on. So far all is good. Just thankful it didn't track to one of the gauge clusters.
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.6041 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-10-26 07:56:07 UTC
