? about changing from a manual fuel pump to electric #1074681 10/13/14 09:50 PM
huntnsonvagun Offline OP
Have any of you fellows changed yours over did you just cap off the lines on the old manual pump or take it off and install a plate and gasket..also what kind of pump do any of you recommend. It is a 1987 dodge raider 2.6 and I have already installed a weber a while back.....do you recommend installing a fuel regulator with the electric pump or not.. thanks for info
Re: ? about changing from a manual fuel pump to electric [Re: huntnsonvagun] #1074682 10/17/14 04:23 AM
zarktheshark Offline
I put a carter p4070 on mine. I also put a regulator on it because it was pushing fuel past the float bowl. It still does it though, but the weber carb is pretty tired. You will have a hard time finding a block off plate for it, I searched pretty hard and could not find one. I made one, but the metal was too thin, so it leaked. I ended up putting my old fuel pump back in, but removed the cam follow arm. To be honest, I don't think I notice a difference and if I were to do it over, I think I would just use the stock one.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: ? about changing from a manual fuel pump to electric [Re: zarktheshark] #1074683 10/17/14 04:31 AM
The starquests have a block off plate stock, about 3-4mm thick, maybe 1/8". You need a fuel regulator set at weber specs for pressure. Webers will take more than a Mikuni, but not much.
Re: ? about changing from a manual fuel pump to electric [Re: zarktheshark] #1074684 10/18/14 02:22 AM
Zark where did you end up mounting that carter at?
Re: ? about changing from a manual fuel pump to electric [Re: huntnsonvagun] #1074685 10/18/14 03:32 AM
I mounted mine by the driver side rear tire. Note that sometimes I get a loud hum sound if the rubber hoses touch any metal, so you will want to prepare for that. To be honest, I think I could have done a better job, but I have plans for EFI, so all of this will be removed someday. Here are 2 pics, not great, but will give you an idea. Also, it did get better when I used the rubber isolators between the pump and the frame. I got them from napa. IIRC, I think I found that running my regulator at 3psi worked best for me.
[img]http://s1006.photobucket.com/user/zarktheshark1/media/weber/100_0015.jpg.html?sort=3&o=12[/img]
[img]http://s1006.photobucket.com/user/zarktheshark1/media/weber/100_0020.jpg.html?sort=3&o=7[/img]
Here is a link to the various pics I took when converting.
weber pics
'15 Subaru XV
'03 BMW i325
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.013s) Memory: 0.6090 MB (Peak: 0.6743 MB) Data Comp: Off Server Time: 2026-11-20 00:15:56 UTC
