Buick 3800 S/C Swap? #1074862 10/27/14 09:12 PM
F
Fujisawa_Rob Offline OP
I know this has been done in Isuzus, anyone ever explore it in a Monty? A 2004 Rodeo bellhousing would bolt to the engine and trans. Would have to custom fab a 4x4 oil pan, and since the supercharged versions are FWD, the throttle body needs a u-bend since it points at the firewall. Solid engine, good HP (probably close to 300), timing chain, alternator up high where it belongs. It's a 90 degree block so would be wider than the 3.5, but I have a 2" body lift to install so that might help if the engine needs to sit a bit higher.
Thoughts?
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Buick 3800 S/C Swap? [Re: Fujisawa_Rob] #1074863 10/27/14 11:40 PM
a 90* 4.3 has been done, so there's no real reason why a 3.8 won't fit. I'd go with a 4.3, myself, with a turbo a la Syclone/Typhoons. In my experience, the 4.3 is a stronger block. I had bad experience with a 3.8 in a buick turbo regal that my ex father in law owned.
Re: Buick 3800 S/C Swap? [Re: fasteddy] #1074864 10/28/14 03:02 PM
F
Perhaps true, but the likelihood of me finding a SyTy engine is pretty low I think. I can find the 3800 SC. Plus the 3800 is distributorless, which the 4.3 wasn't until fairly recently (mid 2000s I believe).
Re: Buick 3800 S/C Swap? [Re: Fujisawa_Rob] #1074865 10/28/14 09:34 PM
Ian Sharpe Offline
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
Re: Buick 3800 S/C Swap? [Re: Fujisawa_Rob] #1074866 10/28/14 10:35 PM
A
azazel Offline
6G72 TT would appear to me to be less work...If I didn't break so many parts this season desert racing I would already be well into the swap.
I do love that GNP motor though!
1994+1995 Montero SR
2003 Montero Limited
1990 Mighty Max 6G72 4x4
2014 Outlander Sport (Wife)
1992 Galant VR4 (724)
2004 Mitsubishi Lancer Evo RS - (SOLD)
+ Other Non Mitsu's
Re: Buick 3800 S/C Swap? [Re: Ian Sharpe] #1074867 10/29/14 12:30 AM
monte3 Offline
Just read through all 6 pages of this build, and the great trips this rig has been on. Took nearly an hour to do it justice... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: Buick 3800 S/C Swap? [Re: Ian Sharpe] #1074868 11/02/14 04:16 PM
F
Nice...I wonder if he'd build and mail me a set of those engine mounts. I figured those would need custom fab, and the oil pan. Buick engine would need a cobra head or u-bend on the intake since it's FWD, unlike the Holden setup.
Re: Buick 3800 S/C Swap? [Re: Fujisawa_Rob] #1074869 11/03/14 08:21 AM
Ian Sharpe Offline
From all reports the HOlden 3.8 is a buick motor or very similar:
Changes in the relative values of the Australian dollar and Japanese yen made it financially impractical to continue with the well-regarded Nissan engine of the VL. Instead, Holden manufactured their own 3.8-litre V6 engine based on a Buick design, adapted from front- to rear-wheel drive.[56]
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6261 MB (Peak: 0.7212 MB) Data Comp: Off Server Time: 2026-06-07 07:29:09 UTC
