Montero SR Cooling Problem - Too Cold
#1074873
10/30/14 03:41 PM
I don't often drive my Montero down to the city...but when I do I run into a strange problem. I am dropping from 9200 feet to 5200 feet in about 25 miles. Thus, almost the entire trip is down hill.
Yesterday the temp was 30-36 deg F.
The truck won't stay warm. The temps can get so low that I don't even get heat from the heater. At idle it will enter the cold loop where it keeps the idle higher than normal.
Before it gets really cold, anyone have any ideas on how to keep the truck warm? I could simply block part of the radiator for the drive down and pull it out for the drive up. Anyone have any better ideas?
1994+1995 Montero SR 2003 Montero Limited 1990 Mighty Max 6G72 4x4 2014 Outlander Sport (Wife) 1992 Galant VR4 (724) 2004 Mitsubishi Lancer Evo RS - (SOLD) + Other Non Mitsu's
Re: Montero SR Cooling Problem - Too Cold
[Re: azazel]
#1074874
10/30/14 04:19 PM
First thing I'd do is replace the stat.
[Re: pcc]
#1074875
10/30/14 05:52 PM
Try placing cardboard in front of the radiator (as you've clearly stated). However, a higher degree t-stat, and a block heater might help.
98 Gen 2.5 05 Pontiac GTO 91 Corvette ZR-1 2011 Kia Sorento (wifey mobile) Clarkdale, AZ
[Re: pcc]
#1074876
10/30/14 06:52 PM
First thing I'd do is replace the stat. +1 If that doesn't do it I'd look at the clutch on the clutch fan. If it's frozen fully locked then it won't be disengaging when the ambient temperatures change. Had this problem on my 'Bird twice before changing to electric and my Sport fan clutch was starting to do this, too, before I changed that to electric a couple years ago. PITA I understand.  Edward
'97 Montero Sport LS 5-Speed 3.5L conversion SAS Dana 44s & ARBs, 35" Yoko Geolandar M/Ts NP231 B4R doubler/Terra Low231/RP 5.38 229:1 '99 Montero Sport Limited 4WD SAS 3-link project '03 Montero Sport Limited AWD '97 Montero Sport LS 5-Speed 4WD
[Re: ES_97Sport]
#1074877
10/30/14 08:19 PM
I am stopping on the way home to pick up a new stat. Going electric on the fan was something I wanted to do.
I didn't even think about the thermostat because I was not having any overheating problems. If that is opening at lower temps then it would cause this problem. Thanks for the idea!
[Re: azazel]
#1074878
10/31/14 10:22 PM
I didn't even think about the thermostat because I was not having any overheating problems. If that is opening at lower temps then it would cause this problem. Thanks for the idea! Make sure you get the correct temperature thermostat. The aftermarket ones are not all created equal and they may or may not start to open and come to full open at the temperatures that they're supposed to irrespective of what they say. A thermostat that doesn't open when the ECM/PCM expects it to will hork up your fuel control and can result in random codes and CEL. Read my posts ... Montero Sport thread - thermostats Edward
[Re: ES_97Sport]
#1074879
11/01/14 11:17 AM
I've never had a "Stant" fail. I recently installed their "SuperStat" in all my vehicles. It is much more robust than standard stats and claims to eliminate large fluctuations in open/close temps, keeping engine at a more even temp. So far so good.
[Re: pcc]
#1074880
11/01/14 06:35 PM
Personally, with the consistently low quality I've seen in all brands and styles of thermostats, I'd recommend testing any thermostat before you install it. Suspend it in a pot of water on the stove to make sure that it opens at the correct temperature and that it opens and closes completely. It's far easier to detect and return a defective thermostat when you haven't installed it on the vehicle.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: ryany]
#1074881
11/03/14 09:27 PM
Personally, with the consistently low quality I've seen in all brands and styles of thermostats, ... This isn't new problem. I've been dealing with crappy thermostats since the beginnings of the '80s. The effects have just gotten worse with computer controlled vehicles. You could get away with a thermostat that didn't open quite when it should or wasn't full open quite when it should be 30 years ago. Not any more. EVERYTHING is tied into ECT even A/T trans shifting. I'd recommend testing any thermostat before you install it. .... OR, you could not waste $20 of your time and just buy one from the dealership. Never had a bad/inaccurate Mitsu thermostat and they last. I've never had a "Stant" fail. I recently installed their "SuperStat" in all my vehicles. It is much more robust than standard stats and claims to eliminate large fluctuations in open/close temps, keeping engine at a more even temp. .... Good marketing on their part. Stupid, but good. So, they managed to charge a premium for a product to do what a normal thermostat should just do in the first place. In other words, they'll sell you the broken part for n $$s but if you want one that WORKS, well, that's extra. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Like I said. Buy a Mitsu thermostat and be done with it. Sigh. Edward
[Re: ES_97Sport]
#1074882
11/04/14 01:25 AM
In other words, they'll sell you the broken part for n $$s but if you want one that WORKS, well, that's extra. Could never tell the difference from the OEM stat, so not sure of your snide, broken part comment. Have you done temp testing you could post of Stant versus OEM so we might all see how the "broken" one differs so much?
