Re: Montero SR Cooling Problem - Too Cold [Re: pcc] #1074883 11/04/14 03:14 AM
ryany Offline
Could never tell the difference from the OEM stat, so not sure of your snide, broken part comment. Have you done temp testing you could post of Stant versus OEM so we might all see how the "broken" one differs so much?
It's been done, and has been proven repeatedly that the aftermarket thermostats have shoddy quality and thoroughly unreliable operation. A little Google searching will certainly get you more than enough reading material about thermostat failures. I've personally had two separate brand new A/M t-stats that I've tested that were off by more than 10 degrees from their stated operating temperature.
95 Montero SR
Re: Montero SR Cooling Problem - Too Cold [Re: ryany] #1074884 11/04/14 03:46 AM
P
pcc Offline
What's an A/M t-stat? Is it a Stant?
Re: Montero SR Cooling Problem - Too Cold [Re: pcc] #1074885 11/04/14 06:16 AM
ryany Offline
A/M = aftermarket
95 Montero SR
Re: Montero SR Cooling Problem - Too Cold [Re: pcc] #1074886 11/04/14 06:52 AM
AZRaider Offline
A/M = aftermarket
And I personally haven't had any issues with aftermarket t-stats, but it wouldn't surprise me if they fail more often since 95% of manufacturers, no matter what their product is, are trying to find cheaper ways of manufacturing, whether that be in the materials they use or the process in which they produce their product.
1987 Dodge Raider, 2.6L, manuel, bone stock with a whole lot of new and refurbished parts. Brought back from the dead after 12yrs.
Re: Montero SR Cooling Problem - Too Cold [Re: AZRaider] #1074887 11/04/14 06:56 AM
AZRaider Offline
Guess I sat on that post a little too long...
Re: Montero SR Cooling Problem - Too Cold [Re: ryany] #1074888 11/04/14 01:49 PM
P
pcc Offline
A/M = aftermarket
Don't think you can lump all A/M stats in same bucket. As I said, I've never had a problem with "Stant". Never once have they displayed any problems with temp control. I can understand some overshoot in opening temp due to manufacturing tolerances and simple design of stat but it certainly has never shown up in temp gauge or engine operation. Stant may even be manufacturing for OEMs.
Re: Montero SR Cooling Problem - Too Cold [Re: pcc] #1074889 11/04/14 04:57 PM
A
azazel Offline OP
I stopped at Mitsubishi and picked up an OEM stat. I have had bad luck with AM stats on my DSM's. It was $15 for the OEM part.
I have it in the truck now. It's 30 deg today but I didn't drive the truck down. I plan to do that tomorrow and it will be about as cold as it is today.
Not that this matters by my Galant VR4 held temps all the way down today and I literally was at idle for 15+ miles. Hoping the Montero does the same tomorrow.
1994+1995 Montero SR
2003 Montero Limited
1990 Mighty Max 6G72 4x4
2014 Outlander Sport (Wife)
1992 Galant VR4 (724)
2004 Mitsubishi Lancer Evo RS - (SOLD)
+ Other Non Mitsu's
Re: Montero SR Cooling Problem - Too Cold [Re: azazel] #1074890 11/05/14 12:32 AM
P
pcc Offline
You can't go wrong with OEM except in price. A Stant Superstat is $9 at Advance Auto. The cost of dealer is not all "quality", a lot is overhead and the fact that they just charge more to make more.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6296 MB (Peak: 0.7441 MB) Data Comp: Off Server Time: 2026-05-29 15:00:27 UTC
