Rear coil springs #1074998 11/07/14 06:56 AM
bombardj1 Offline OP
I noticed when checking my fuel tank for the back splash of gas. That I have a broken coil spring. I think I can get stock ones for a little bit over $30 at rockauto made by Moog part numbers 81381. Besides the dealer does anyone know where I can get the rubber seats ?
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: Rear coil springs [Re: bombardj1] #1074999 11/07/14 06:40 PM
Peabody Offline
Other than the dealer or a salvage yard, I don't know where else to get them. But they aren't fancy items. You can fabricate one from any basic form of rubberized sheet, such as indoor/outdoor v-groove matting, preferably the type with fabric mesh in the base. You can get the matting at HD or Lowes. I'd double the thickness on the matting by meshing the v-grooves together. You could glue them together with contact cement to keep them solid. Just a thought...
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5887 MB (Peak: 0.6365 MB) Data Comp: Off Server Time: 2026-06-07 07:28:56 UTC
