torque converter swap help..all apart and confused #1075200 11/16/14 01:33 AM
boostin Offline OP
Hey guys I have my 89 mighty max 4 cyl auto all apart and have a v6 converter I was going to swap on as I read herr several times that it's a direct swap but both transmission input shafts look very different.. any advice..both are non lock up
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD!
1989 Mighty Max 2WD 2.6 5 speed slammed
1993 Eagle Talon TSI
Re: torque converter swap help..all apart and confused [Re: boostin] #1075201 11/16/14 06:46 PM
TainterRacing Offline
mmmm I think you have to use the V6 auto....
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: torque converter swap help..all apart and confused [Re: TainterRacing] #1075202 11/17/14 02:54 AM
boostin Offline OP
Well I think I got it. I changed the oil pump and front shaft...I was concerned of the condition if the v6 mystery trans. All together now and works great huge improvement with the turbo!
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.5922 MB (Peak: 0.6453 MB) Data Comp: Off Server Time: 2026-06-07 06:00:01 UTC
