Rating: 4
Crank to power window conversion? #1075420 12/06/14 04:49 AM
bodyswapped8789 Offline OP
Has anybody done it? Found a pretty complete 84 montero at the yard. Should have what I need. I'm thinking there will be in intermediate wire harness, relay, switches, door cards even match my interior, and window regulator and motor. I would think the tracks will be the same, but the windows may need to be replaced too, not sure without looking at them and comparing to mine. I know it may sound silly and a lot of work but I like doing that stuff and it's my daily driver now.
89 V6 manual trans Dodge Raider frame 87 cold weather pkg 2" body lift, Soft 8's wraped in BFG km2 33x10.5x15, JDM Pajero yellow Bosch fogs. Yackama basket. Duel bouncies gen II rear springs,gen II ft brakes,master and booster.
Re: Crank to power window conversion? [Re: bodyswapped8789] #1075421 12/06/14 05:26 AM
Lloyd Swartz Offline
As tough as a V8 engine swap? maybe not, but damn tough. The mechanism is the tough part. If I recall much of the wiring is there, but getting the frames and cables all installed right...I would not attempt it.
Re: Crank to power window conversion? [Re: Lloyd Swartz] #1075422 12/06/14 06:06 AM
The doors are the same. All the holes for the motors and screw placements already exist. However, you'll have to make your own harness to get power to the doors, as Mitsu in their vision did not make the harnesses modular, but based upon the options for each particular chassis....based upon the vehicles I've parted down only.
Tracks and glass are the same, just will take your sweet time for the install. I almost did this conversion for my Raider using all the 4-door parts I've had.
Re: Crank to power window conversion? [Re: rxinhed] #1075423 12/06/14 08:20 AM
Jay Ayala Offline
I will soon be attempting this on my 1989 Raider and plan on fully documenting the how to.
Re: Crank to power window conversion? [Re: Jay Ayala] #1075424 12/06/14 03:24 PM
Bernoulli Offline
Based on the Pajero I had in Australia:
The window circuit is made by grounding it.
I would do each door (on a 2dr) separately and not worry about controlling the passenger side window from the driver's side.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Crank to power window conversion? [Re: bodyswapped8789] #1075425 12/06/14 06:07 PM
Malykaii Offline
So I'm not the only one. I was going to ask the very dame question come spring.
My doors have gotten so bad from offroading... Only ones I can find are power. I ended up banging my current ones back into shape and was going to swap the power window stuff over, as I don't want to bother painting silver doors blue.
So your saying the hard part is swapping the power regulator and getting it all to line up? So it would just be easier to swap the whole doors and paint them?
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: Crank to power window conversion? [Re: Bernoulli] #1075426 12/06/14 06:21 PM
Malykaii Offline
OP, maybe that would be a good option for you too? Just swap the whole doors?
Bernoulli... So your saying there are no relays or modules? Just run power and ground and all the rest is in the door?
Re: Crank to power window conversion? [Re: Malykaii] #1075427 12/06/14 06:42 PM
haztoys Offline
You really miss this one ...
Doors are the same .... (The Montys 'I've' played with..) The wirings in the truck to the door frame and the wiring for the relay is there ... But
Theres a few different ways Mitsu did it... So the wiring you 'find' may need to be played with to get it all to work ...Key is to see if your truck has ......What ...?
Power window power locks or .....?
Re: Crank to power window conversion? [Re: haztoys] #1075428 12/06/14 10:50 PM
The stock power windows in my '86 are so weird that they ONLY work when the engine is running. They will not work when the key is in any position when the engine is not running, and it was that way before the swap from the stock 2.6 to the 2.4 that's in it now. When the engine dies with the windows down, it's not great if you can't get it started again for, say, a month...
Re: Crank to power window conversion? [Re: Malykaii] #1075429 12/07/14 04:15 AM
I don't think the regulators are going to be the hard part. The crank should be similar to the regulator just with a motor attached. I think the more challenging part is going to be wiring the relays figuring our where the best place to put it all. I'm going to pull the dash and replace the 87 with the 89 dash for round speakers and it's in better shape then mine anyhow so I have all the access I'll need. I looked at the repair manual and looks petty straight foward, not sure what the sub switch is all about but.. Thinking I can tap into the fuse box already on my harness, there is two unused spots.. Going to the yard tomorrow so I'll let you all know what I find out. If I do it I'll document the build too.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6397 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-06-07 06:07:25 UTC
