Sad day. Raider Broke down - Head gasket? #1075440 12/06/14 08:22 AM
zarktheshark Offline OP
I have been slowly building up the Raider and today on the way home from work I see I huge cloud of smoke come out from behind me; and then I realize that it's me. Only 35k on the rebuild <img src="/forums/images/graemlins/frown.gif" alt="" /> Not sure what exactly happened, but I smelled antifreeze and the water is milky. I have a Clearwater head on it. What do you think, head gasket or something else? no rods sticking out of the block that I could see but it was dark. Will investigate more in the morning.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Sad day. Raider Broke down - Head gasket? [Re: zarktheshark] #1075441 12/06/14 09:34 PM
Malykaii Offline
Yes the head can crack or head gasket go, but on the 2.6 it usually happens for a reason. Any issues with overheating? Did the temp gauge read half way the whole time? Do you have a coolant pressure tester?
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: Sad day. Raider Broke down - Head gasket? [Re: zarktheshark] #1075442 12/06/14 09:39 PM
Malykaii Offline
Also, I see in your signature that you have 4.90s in your 88. When you get your problem figured out, would you have a moment to tell me what/how you did it? Thanks.
Re: Sad day. Raider Broke down - Head gasket? [Re: zarktheshark] #1075443 12/07/14 01:09 AM
ryany Offline
I assume you mean the oil is milky...
There are only few ways that coolant can get into your oil, and if it's coupled with coolant or oil being burned in your combustion chamber then it's either a blown head gasket or a cracked head. The only thing to do at this point is tear it down and find out if it's just the head gasket, and you'll want to do that as soon as possible since coolant in your oil is pretty hard on bearings.
You'll also want to triple check the cooling system as overheating is the likeliest cause of your problem. If you have any reason to doubt the efficiency of your radiator, now is the time to get it rodded out.
95 Montero SR
Re: Sad day. Raider Broke down - Head gasket? [Re: ryany] #1075444 12/07/14 05:54 AM
haztoys Offline
Sorry on the the DOA motor ..Hope its just <img src="/forums/images/graemlins/zombie.gif" alt="" /> the head gasket ...May I ask ..Did you re-torque the head ...?
Re: Sad day. Raider Broke down - Head gasket? [Re: haztoys] #1075445 12/07/14 06:40 AM
Thanks for the replies. I did not re-torque the head. When is that supposed to be done? I was not the one to rebuild it and the shop has since went out of business. Temp has be good. never going over 1\2 on the gauge. I just had an oil change and flushed the radiator because I accidently grabbed the distilled vinegar jug instead of the distilled water. That said, I had to put water in it because it got low, but I could not find any leaks. No steam coming out of the tailpipe and oil looked fine. I only got about 2 cups of vinegar in it before I smelled it and realized what I had done.
'15 Subaru XV
'03 BMW i325
Re: Sad day. Raider Broke down - Head gasket? [Re: zarktheshark] #1075446 12/07/14 04:35 PM
Bernoulli Offline
If you had to add water, there was already a small leak. I hope it's only the gasket!
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Sad day. Raider Broke down - Head gasket? [Re: Bernoulli] #1075447 12/07/14 07:26 PM
Yeah, that's what I was thinking to. Any tips for flushing out the contaminated oil? I'm going to pull the head today.
'15 Subaru XV
'03 BMW i325
Re: Sad day. Raider Broke down - Head gasket? [Re: zarktheshark] #1075448 12/07/14 11:17 PM
Well, it wasn't the head gasket. What the heck would cause this?
see attached
'15 Subaru XV
'03 BMW i325
Re: Sad day. Raider Broke down - Head gasket? [Re: zarktheshark] #1075449 12/07/14 11:25 PM
ryany Offline
Holy crap Batman! There's a hole in your piston!
There had to be something seriously wrong for that to happen - either the ignition timing was way too advanced or the mixture got really lean.
95 Montero SR
PHP: 7.4.33 Page Time: 0.008s Queries: 17 (0.005s) Memory: 0.6449 MB (Peak: 0.7803 MB) Data Comp: Off Server Time: 2026-06-20 18:18:03 UTC
