3.0L Coolant Drain Plug? #1075550 12/11/14 02:11 AM
Bernoulli Offline OP
My manual says to remove it to drain cooling system. Is there one? Where is it?
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: 3.0L Coolant Drain Plug? [Re: Bernoulli] #1075551 12/11/14 03:10 AM
plh Offline
bottom of the radiator.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: 3.0L Coolant Drain Plug? [Re: plh] #1075552 12/11/14 03:48 AM
Jay Ayala Offline
Bottom Passenger side. Usually it has a little hose dangling from the drain cock.
Re: 3.0L Coolant Drain Plug? [Re: Bernoulli] #1075553 12/11/14 08:04 PM
Poor choice of words. The one on the radiator I know. I forgot to say engine coolant drain plug. My manual says there is one, but I can't find it in any of the drawings. I'd like to drain it all so I can replace it all.
Re: 3.0L Coolant Drain Plug? [Re: Bernoulli] #1075554 12/12/14 06:05 AM
Jay Ayala Offline
Hmm...
I think I got a picture of it. Let me see if I can find it.
I got it. 11 years ago I put yellow enamel on my 3.0L block. I just found that old picture. Let's see if I got this location right. Lower passenger side of block just above where the starter would typically be. Take a look at this image, it looks like a bolt protruding out of the block.
[img]https://lh6.googleusercontent.com/OvqLMn2_sTtETXQohR2uhqd6-Hml3xRmJuMCrX_3WZI=w542-h406-p-no[/img]
Re: 3.0L Coolant Drain Plug? [Re: Bernoulli] #1075555 12/12/14 09:14 AM
Jay Ayala Offline
There are two drain plugs on the engine block. They sit pretty low on the block. Approximately three inches above the oil pan flange. Assuming you are talking about 3.0L of course.
Passenger side: just above the starter close to bell housing flange.
Driver side: toward front just between the A/C bracket and engine mount.
In both cases, the look and feel like bolts protruding from the engine block.
Re: 3.0L Coolant Drain Plug? [Re: Jay Ayala] #1075556 12/12/14 05:56 PM
Jay Ayala Offline
I found those pictures.
The first picture is passenger side. You can easily see the drain plug. The second picture is the driver side, the drain plug is kind of hard to make out, it is being slightly obscured by the orange strap.
Re: 3.0L Coolant Drain Plug? [Re: Jay Ayala] #1075557 12/15/14 05:24 PM
Thank you Jay! I'll crawl under and take pix if I can spot them.
Re: 3.0L Coolant Drain Plug? [Re: Bernoulli] #1075558 12/18/14 05:14 PM
I don't believe I can get to the plugs. How about just changing the water in the radiator every day until it's clean? Or... taking out the thermostat and running the engine with a hose emptying in the radiator and the engine return hose disconnected? I use to do that on my Power Wagon.
Re: 3.0L Coolant Drain Plug? [Re: Bernoulli] #1075559 12/18/14 08:31 PM
Jay Ayala Offline
That hose trick should work.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6316 MB (Peak: 0.7555 MB) Data Comp: Off Server Time: 2026-10-24 23:54:53 UTC
