Special tool needed to keep lash adjusters in place? 3.5 SOHC #1075566 12/11/14 02:29 PM
F
Fujisawa_Rob Offline OP
So...heads pressure tested fine after broken timing belt. I'm going to pull the valves and check them with a dial indicator and replace the seals. FSM says I need MD998443 to keep the lash adjusters in place during disassembly. Is there a cheaper alternative? Can I get by without this tool?
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Special tool needed to keep lash adjusters in place? 3.5 SOHC [Re: Fujisawa_Rob] #1075567 12/11/14 06:21 PM
Jay Ayala Offline
I can tell you fasteddy always recommend taking apair of scissors to latex gloves. Just use the finger tips to hold them in place.
Re: Special tool needed to keep lash adjusters in place? 3.5 SOHC [Re: Jay Ayala] #1075568 12/11/14 07:09 PM
F
Seems like that would work.
Re: Special tool needed to keep lash adjusters in place? 3.5 SOHC [Re: Fujisawa_Rob] #1075569 12/12/14 04:07 AM
boostin Offline
If it's like the 2.6 set up I use a bike tube cut into 3" sections or so
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD!
1989 Mighty Max 2WD 2.6 5 speed slammed
1993 Eagle Talon TSI
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6567 MB) Data Comp: Off Server Time: 2026-06-07 06:07:33 UTC
