2wd mighty max lift? or longer travel? #1075576 12/12/14 05:23 AM
boostin Offline OP
hey guys
kinda thinking about adding a third mighty max to the fleet. since i have lowered and slightyly lifted 4wd i was thinking logically 2wd pre runner makes sense.
I am not making a serious pre runner that i would be in the desert jumping just something with a bit more travel and smoother then stock. hit some logging roads or light trails.
From what |I have read there are basically no options for the mighty max except i have read people used slightly stiffer springs to get some extra lift.
thinking something like a 4wd stance and some 235/75/15 tires, tube front bumper and cool roll bar, 4.62 lsd gears and some engine tweaks
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD!
1989 Mighty Max 2WD 2.6 5 speed slammed
1993 Eagle Talon TSI
Re: 2wd mighty max lift? or longer travel? [Re: boostin] #1075577 12/12/14 05:47 AM
boostin Offline OP
http://www.gearboxmagazine.com/jace-tuttle-2/
maybe i am thinking more a rally truck
Re: 2wd mighty max lift? or longer travel? [Re: boostin] #1075578 12/12/14 09:07 PM
How about this?
4x4Wire ad
Has a 4.625 LSD installed in the rear now, and I have everything for same in front. Has turbo. Has 4wd. Has stick shift. Has AC. has 3" stainless exhaust and high flow cat. Comes with lots of parts, including some Montero torsion bars. And, I'd make you a better than advertised price deal. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 2wd mighty max lift? or longer travel? [Re: boostin] #1075579 12/12/14 10:17 PM
For long travel IFS use 2WD sport front arms and steering, I THINK you can additionally run early Gen 2(12v 3.0) front torsion bars to make it ride a little higher but super smooth. Measure the lengths to be sure.
Alternatively you could run coilovers up front easily because you'll have no front axles.
Re: 2wd mighty max lift? or longer travel? [Re: TOASTY] #1075580 12/12/14 11:18 PM
boostin Offline OP
Hmm forgot about 2wd Montero sports..it has coils so could not use torsen bars
Re: 2wd mighty max lift? or longer travel? [Re: boostin] #1075581 12/13/14 02:09 AM
2wd MM and D50s use front coils and not torsion bars. Steering linkage is behind the engine cross member. Many were Armstrong steering, too.
Re: 2wd mighty max lift? or longer travel? [Re: rxinhed] #1075582 12/13/14 04:40 AM
That's right! could just make longer arms and longer everthing else fairly easily.
PHP: 7.4.33 Page Time: 0.229s Queries: 15 (0.222s) Memory: 0.6194 MB (Peak: 0.6944 MB) Data Comp: Off Server Time: 2026-10-26 09:11:13 UTC
