SR brake info #1075614 12/14/14 09:35 PM
haztoys Offline OP
I know you have to have hub and rotor cliper and mount on a SR big brakes on a gen1 ..I have it all ...But one hub and rotor ...
Is the hub and rotor 'only' on a SR ......Or..
Thanks
Re: SR brake info [Re: haztoys] #1075615 12/15/14 04:50 PM
I
IncorpoRatedX Offline
I was under the impression that it was a caliper upgrade and the rotor diameter is the same.
I hope so, just ordered calipers and brackets saturday
V45W - 1999, 3.5 sohc, winter package
L042G- 1987, 2.6 carb, auto - Cylon Raider
A112 - 1973 Galant Wagon - 4G63 Turbo, 5 speed
L023G - 1983, 2.6 carb, 5 speed manual 4WD
L028 - 1983, 4D55 turbo diesel 2WD
Re: SR brake info [Re: IncorpoRatedX] #1075616 12/17/14 04:15 AM
All the gen 2s with 3.5 have the same brakes for sure. Possibly the 3.0 powered trucks as well.
Re: SR brake info [Re: TOASTY] #1075617 12/19/14 07:15 PM
haztoys Offline OP
Now I'm speaking of the 'wheel hub' off set.. I know that the right w-hub has a "cut" on it so you can tell its the right one ..The one hub I got off the SR has the 'cut' on it ... Do to old age I forgot what I snaged the other hub from ... I guess I need to dig the parts out of the stash and look at them ...I dont want to spit a brake pad ...
Re: SR brake info [Re: TOASTY] #1075618 12/20/14 11:53 PM
Oso Offline
gen 1 rotors are thinner. if you go to gen 2 calipers on a gen 1 you need the rotors too. justice posted awhile back about this as a safety issue .
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6037 MB (Peak: 0.6677 MB) Data Comp: Off Server Time: 2026-07-13 18:57:33 UTC
