Pwr window control relay #1075642 12/17/14 01:47 AM
bodyswapped8789 Offline OP
I need a pwr window control relay and the 7 way connector with at least 3 or so inches of wire so I can spice on to em.
89 V6 manual trans Dodge Raider frame 87 cold weather pkg 2" body lift, Soft 8's wraped in BFG km2 33x10.5x15, JDM Pajero yellow Bosch fogs. Yackama basket. Duel bouncies gen II rear springs,gen II ft brakes,master and booster.
Re: Pwr window control relay [Re: bodyswapped8789] #1075643 12/17/14 02:50 AM
The power window relay is found, according to the FSM, right next the intermittent wiper relay on the left side kick panel. I'm sure to have this, but will verify in the light of tomorrow morning.
Re: Pwr window control relay [Re: rxinhed] #1075644 12/27/14 02:51 AM
The relay next to the wiper relay is the pwr relay for power and is a four way connector. I'm looking for the control relay an the 7 way connector. The 89 raider FSM shows it in the driver door. I have the door harness from an 88 montero w/a 2.6. It's not in the door and have no connector on the door harness for it? Thank for your help.
Re: Pwr window control relay [Re: bodyswapped8789] #1075645 12/27/14 04:47 AM
I have that for sure. Sunday before I can pull the piece.
Re: Pwr window control relay [Re: rxinhed] #1075646 12/29/14 02:35 AM
Awesome thanks!! Where was it mounted on the vehicle? Can't find any info in the FSM other then 89, like I said.
Re: Pwr window control relay [Re: bodyswapped8789] #1075647 12/31/14 05:20 AM
Part pic. Located on driver's door. Sunday got away from me with family duties, and I'm scrambling for others too.
Re: Pwr window control relay [Re: rxinhed] #1075648 01/01/15 04:22 PM
No worries I'm not in a big hurry, spring project. That would be the one! I need the controler and the harness connector with as much wire as you can so I can spice wire onto it clean. Let me know what you want for it.
Re: Pwr window control relay [Re: bodyswapped8789] #1075649 01/02/15 03:54 AM
Can do. Will pull everything this weekend when I'm off again.
Re: Pwr window control relay [Re: rxinhed] #1075650 01/18/15 11:56 PM
Have worked all but two days since then. Raining today, part is off and ready to be boxed.
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6300 MB (Peak: 0.7176 MB) Data Comp: Off Server Time: 2026-06-07 11:38:05 UTC
