Rating: 4
After-mudding adventure #1075782 12/27/14 04:27 PM
BOPOH Offline OP
Hello, some of you may follow my thread on EXPO but i thought i would share pictures too. Basically what happen - i thought i blew my engine was planning to swap it, but everytime i unscrew something big i was finding new surprises. Right now i know my torque converter bolt came out, scratched torque converer and cracked tranny bell housing. I think it got stock between starter and flywheel preventing me to start the engine. There was oil puddle on the ground some we thought bearing shot through the oil pan, but oil relief valve got stuck and oil pressure was through the roof so it was leaking from cranshaft seal with oil pan intact. I'm taking everything apart to check for damages, changing gaskets and hoping that when i reassemble i don't find another issue. Not sure if i should crankshaft for signs of wear by taking of all the pistons.
Re: After-mudding adventure [Re: BOPOH] #1075783 12/27/14 04:29 PM
BOPOH Offline OP
my little templates
those bolts missing because i used them to remove oil pan - perfect fit
those caps are perfect covers for spark plug tubes, just enough tension to stay and let air in so it's easy to spin crankshaft
Here are the things from the top
There is my bottom end
Bit dirty, actually there WAS a little twig stuck in it, how the hell it got there?
dirty cylinders inside
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1050002_zpsf6f3d5af.jpg[/img]
Here is the truth about engine flush - it doesn't work!!!
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1040895_zps17807542.jpg[/img]
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1050001_zpse1965784.jpg[/img]
Oil pump removal
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1050005_zpsdac31bd1.jpg[/img]
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1050008_zps8a181005.jpg[/img]
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1050009_zps3ca47d94.jpg[/img]
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1050007_zps92e95150.jpg[/img]
Front seal aka crankshaft seal - stubborn little bugger
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1050010_zpsa7a23237.jpg[/img]
Here is my next tearing down/cleaning project
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1040901_zps21456b8e.jpg[/img]
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/P1040900_zpsd0bc37a2.jpg[/img]
That's it for night, gotta figure out how to clean all that crap from the block. any suggestions anyone?
Re: After-mudding adventure [Re: BOPOH] #1075784 12/27/14 04:29 PM
BOPOH Offline OP
cleaned out oil pump and have some questions
it was so dirty that last piece didnt want to come out
I end up using 1/2 bolt with paper towel to screw in that piece to get it out
After all was cleaned, i filled it up with oil and spun couple of times and it was leaking from the shaft connector, is it normal?
After that i decided to clean out alternator - it was like a nest in there
Re: After-mudding adventure [Re: BOPOH] #1075785 12/27/14 04:30 PM
BOPOH Offline OP
also cleaned out oil pan - before and after
[Linked Image][Linked Image]
Oil filter and by-pass bracket, it was so dirty that you couldn't even see the shape of it
Re: After-mudding adventure [Re: BOPOH] #1075786 12/29/14 10:33 PM
Lloyd Swartz Offline
Wow, and I thought my last mud adventure was impressive. The alternator tells the story <img src="/forums/images/graemlins/scared.gif" alt="" />
Those Torque converter bolts on these old rigs do have a tendency to wiggle out unfortunately.
Re: After-mudding adventure [Re: Lloyd Swartz] #1075787 12/30/14 12:43 AM
Oso Offline
IIRC torque converter bolts are single use as they stretch when tightened. Probably a good idea to replace them. Mine were about $6 each from the dealer.
Re: After-mudding adventure [Re: BOPOH] #1075788 01/05/15 01:38 AM
DVoeks Offline
Boy was there some gunk in your oil pan. I've never seen one that dirty on the inside. How many miles on the motor? Do you think that's grit from dust going through your air intake?
97' Montero SR
99' F250 SCLB 7.3
Re: After-mudding adventure [Re: DVoeks] #1075789 01/05/15 02:29 AM
Wow! you got in it bad, now you're doing a full rebuild?
Re: After-mudding adventure [Re: TOASTY] #1075790 01/07/15 12:56 AM
BOPOH Offline OP
Hi guys, sorry didn't check earlier. I was going to do a full rebuild and got it all apart, took to two machine shops and they both said that crank and head are worn out beyond repair. Crank and pistons are all loose, on head cams ate through aluminum and loose as well. Dirt in the oil pan i think is sand mixed with oil, maybe it got there from dipstick tube. But oil was horrible when i checked it after got out the mud, apparently on the spot oil change didn't help.
This morning i got 3.5L engine from 99 momntero but entire oil pan is different. I've searched all around Ohio and nothing exact same as mine, extremely weird and kinda scary.
My plan is to swap oil pans, pick up tube and maybe oil pump if i can't use the one on the engine, get it in the truck and see if it runs. If all goes well i'll leave it until summer for in depth rebuild like head gasket and things. Timing belt is a maybe at this point, if it's good than i'll leave it, if not i'll have to do it. The reason i don't want to do complete timing belt is because if i have leaky seals i dont want to damage new belt.
If you'd like guys i can post more pictures
Re: After-mudding adventure [Re: BOPOH] #1075791 01/07/15 03:39 PM
BOPOH Offline OP
last night got another engine on the stand and took it apart comparing how different it is
Timing belt looks good and almost nothing is leaking only a little from driver side front cam seal
other than that somebody did a horrible job with RTV
Bolts are different length, good think i saved and labeled mine
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/WP_20150106_008_zpse6ed2288.jpg[/img]
Great investment $0.50 for cleaing
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/WP_20150106_009_zpsdac50d45.jpg[/img]
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/WP_20150106_010_zps7b8adb6a.jpg[/img]
[img]http://i219.photobucket.com/albums/cc198/BOPOHkgb/Pajero/WP_20150106_011_zpsdcd0b416.jpg[/img]
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6518 MB (Peak: 0.7899 MB) Data Comp: Off Server Time: 2026-05-29 22:46:45 UTC
