Page 3 of 3 1 2 3
Re: Heater Core [Re: plh] #1075954 01/05/15 04:12 AM
9
97LSMonty Offline OP
Yes, the core it self is thinner, like about 1/2 inch. But with the case that surounds the core it fills up almost the whole hole. I think it moves about an eighth, but with the insulation foam its sturdy...
Re: Heater Core [Re: 97LSMonty] #1075955 01/27/15 10:31 PM
9
OK... The Dash removal video is up and should be live in about 77 minutes (according to youtube) here is the link
http://youtu.be/VyDP1QUncHg
I will be working on the HVAC removal next. Thank you for your patience for those that have PM'd me thank you for your support.
Things I Learned
1. Your blinkers wont work with our the Hazards switch plugged in
2. This job isnt as bad as the FSM makes it look
3. I really like working on my car.
4. Take your time when custom work is needed.
5. There are different evap and expansion valve setups.
Enjoy...
Re: Heater Core [Re: 97LSMonty] #1075956 01/28/15 02:22 AM
Jay Ayala Offline
Hey I just tried to view the video. YouTube says the video is Private. You need to change it to public.
Re: Heater Core [Re: Jay Ayala] #1075957 01/28/15 07:05 AM
9
Thanks for the heads up. It should be good now.
Re: Heater Core [Re: 97LSMonty] #1075958 01/28/15 07:33 PM
Jay Ayala Offline
I just watched your video. That is excellent content, great job. I changed the heater core on my old 1997 Montero SR. I also went through this pain staking process of removing the dash.
I would suggest that if you have any light bulbs that are out in your dash or your center console, now is the time to change them. I made the mistake of not doing it myself at the time and had to go back into the dash a second time.
Re: Heater Core [Re: Jay Ayala] #1075959 01/29/15 05:05 AM
9
Great Idea... I was thinking about moving all my alarm/remote starter to the center console. I will look for a change all my bad bulbs, And probably do the LED swap out.
Thanks for the info on the video, much appreciated.
Re: Heater Core [Re: 97LSMonty] #1075960 02/04/15 07:41 AM
E
eurosonic Offline
did you get that heater core installed?
Im having similar issues and thinking of getting the same unit you got.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6226 MB (Peak: 0.7132 MB) Data Comp: Off Server Time: 2026-07-17 05:22:01 UTC
