Gen 1 V6 Accelerator Pedel Sticks to the Floor #1076163 01/08/15 08:17 PM
mrray Offline OP
Hey all. I'm still working on getting her back to road-worthiness after a long battle with an electrical issue (http://www.4x4wire.com/forums/showthreaded.php?Cat=0&Board=UBB69&Number=1254825&fpart=&PHPSESSID=) ending in a draw / workaround and issues secondary to sitting for so long. I've been venturing out around the neighborhood to keep her moving parts exercised.
Today (its cold) I had a hard time starting her, and was pumping the gas pedel when it just went limp. At the same time, the engine decided to fire. An important note is that my electrical problem workaround was to run alligator clips from battery to fuel pump check terminal. I still havent gotten around to installing a switch on the dash so I have to get out and disconnect the clip to cut the engine. So when the engine fired up it went full monty--pretty scary. It seemed like it took an eternity to get to that alligator clip.
Engine seems ok. But it appears that the problem is the (let me know if I'm using terms that are too highly technical here) "thingy" that pulls the cable back to neutral position isn't working. When I close the throttle by hand, the "decelerator?" cable that is supposed to be pulling it closed gets slack. The "thingy" seems to be more than a spring-loaded mechanism, as the cable "downstream" of the throttle linkage disappears into a housing that has what appears to be a black capacitor or transformer and various other mysterious components.
Never dealt with this problem before, and a search here suggests it isn't common as I couldn't find a single thread discussing it. Haynes manual is no help.
Any ideas? I don't want to end up inside the dining area of a Waffle House unless I'm on foot.
1991 Montero LS (LWB) 3.0L V6 Stock 205K Miles
Re: Gen 1 V6 Accelerator Pedel Sticks to the Floor [Re: mrray] #1076164 01/08/15 10:16 PM
heathdogg Offline
My 2 bits would be the cable is sticking the housing. Might need some lube in it. Their are various things for that. You can use a cable lube from the Motorbike shop. Some of those come with the spray can of lube and a "luber", a clamp that seals against the housing to allow the lube to penetrate the housing. Unhook the cable from the throttle body and see how free it moves. If it is stiff, might need to be lubed. Sometimes they need to cleaned before lubing. (Gee I like that word, LUBE!) <img src="/forums/images/graemlins/lol.gif" alt="" />
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Gen 1 V6 Accelerator Pedel Sticks to the Floor [Re: mrray] #1076165 01/08/15 11:12 PM
plh Offline
Any ideas?
Do you have cruise control? Is this the module? Aftermarket?
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Gen 1 V6 Accelerator Pedel Sticks to the Floor [Re: heathdogg] #1076166 01/09/15 02:28 AM
mrray Offline OP
LUBE! Thanks. Given its lack of usage and the temp your LUBE theory does make sense. However, pushing the cable back into the "thingy", there is little to no resistance. That has me worried that something has become detached. I'll check more closely though.
Re: Gen 1 V6 Accelerator Pedel Sticks to the Floor [Re: plh] #1076167 01/09/15 02:29 AM
mrray Offline OP
Any ideas?
Oh yeah! I bet that is indeed what that box is. I do have cruise and the vehicle is all stock AFAIK. I don't really need cruise...
Re: Gen 1 V6 Accelerator Pedel Sticks to the Floor [Re: mrray] #1076168 01/10/15 12:57 AM
mrray Offline OP
Well I put a little lube on the cable, charged the battery overnight, and made sure throttle was in the proper position and started her up today. No problems. I'm thinking that that module was indeed the cruise module, and for whatever reason it was stuck after sitting for a week and in the cold weather (9F). I played with the pedel and was not able to reproduce the symptom, so hopefully it was just an anomaly, maybe related to the way I have it rigged up electrically.
Thanks very much Heathdogg and PLH for your input! Will report back if anything further develops.
Re: Gen 1 V6 Accelerator Pedel Sticks to the Floor [Re: mrray] #1076169 01/10/15 01:00 AM
Jay Ayala Offline
Hello MrRay, is there any way you could take a photo for us?
Re: Gen 1 V6 Accelerator Pedel Sticks to the Floor [Re: Jay Ayala] #1076170 01/10/15 01:47 AM
mrray Offline OP
Sure thing Jay. Thanks for the interest! 1st pic is zoomed out. You can see the 2 cables coming from the TB to the module.
web page
2nd pic (next post) is the box I'm referring to.
web page
Re: Gen 1 V6 Accelerator Pedel Sticks to the Floor [Re: mrray] #1076171 01/10/15 01:49 AM
mrray Offline OP
2nd pic
web page
Re: Gen 1 V6 Accelerator Pedel Sticks to the Floor [Re: mrray] #1076172 01/10/15 01:51 AM
mrray Offline OP
Ok. So the file attachment feature apparently does not work. I'll upload these to Picasa and html link in the posts. Gonna take a minute...
UPDATE: See "web page" links within the posts. Disregard the attachments.
PHP: 7.4.33 Page Time: 0.009s Queries: 18 (0.006s) Memory: 0.6406 MB (Peak: 0.7842 MB) Data Comp: Off Server Time: 2026-06-07 04:47:29 UTC
