New Member of the family #1076377 01/20/15 09:02 AM
jdavis Offline OP
Hey guys picked up a '94 LS Montero today for cheap.
After replacing the water pump the previous owner says it threw a rod. He can turn the engine about a quarter turn then it seizes.
Have a line on a 3.0 from from a '99 Sport, would this engine be a direct swap? concerned the ECU will not be compatible.
Thanks,
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: New Member of the family [Re: jdavis] #1076378 01/20/15 04:37 PM
It'll be close, that '94 should have the earliest 24v 3.0. You'll be swapping the oil pan and pickup tube for sure though.
Check to make sure you have crank and cam sensors on both trucks then i'd say go for it.
Now if your '94 is a 12v it's a lot more involved.
Note: 12v has 1 coil and 24v has 3 <easiest way to tell if you're not familiar
Re: New Member of the family [Re: TOASTY] #1076379 01/20/15 07:14 PM
jdavis Offline OP
Thanks for the info Toasty.
It looks like the 12v to me
https://yezjsg.dm2301.livefilestore.com/...ero3.jpg?psid=1
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5951 MB (Peak: 0.6493 MB) Data Comp: Off Server Time: 2026-05-29 20:01:41 UTC
