Rating: 5
Page 2 of 3 1 2 3
Re: 1989 v-6 loses power [Re: haztoys] #1076450 01/26/15 05:58 AM
Good to see someone try the 'Wiring tune up'... Now your ECU is not going crazy now ... Did you noticed the wires 'going dark' at the plugs under the hood .. See lots of died Mitsu's with all the wires under the hood 'going dark' at the plugs ..Its about the copper wire not liking where they meet the conecters...Over time ...
Mitsu's dont have bad ECU's ..Its the wires to the ECU that kills the ECU...
Lots of dark wires, sure it has a lot to do with things not working right.
Re: 1989 v-6 loses power [Re: Oso] #1076451 01/26/15 06:04 AM
Anyone have a link to the "wiring tune up". I see a lot of my probably future here. FWIW I searched it and nothing came up.
Mongo, in mitsubishilinks.com, there is a manual for the 89 3.0, called "Driveability and something else" There is a page in therethat has all the connectors on the engine. I ran off that page and used it as a checklist. Sorry, can't link it from my phone, can't use the laptop, my lady is doing her homework.
Re: 1989 v-6 loses power [Re: Oso] #1076452 01/26/15 01:34 PM
METALMOVER Offline OP
Ill need to find it to.
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: 1989 v-6 loses power [Re: METALMOVER] #1076453 01/26/15 07:19 PM
BLKRaider Offline
A few years ago I had a similar issue with an '89 3.0. It would kill as if keyed off, then restart in a while and run fine. It got peogressively worse. Turned out to be the optical sensor in the distributor, about $60 from Rockauto.
Re: 1989 v-6 loses power [Re: BLKRaider] #1076454 01/29/15 01:11 PM
just, did that about 2 months ago,
Re: 1989 v-6 loses power [Re: haztoys] #1076455 02/01/15 02:19 PM
Well, I sent the ECU off to AVPRO in Fla.talked to nick you guys were right the ECU was fine, he did clean all the connectors cause the had scaling on them although I did the soak em in vinegar remedy 3 months ago, he didn't charge me anything very honest guy. Id recommend them.So I proceeded to pull all the electrical connectors I could get to(including the TPS and Ignitor)no brown wires...sprayed electrical cleaner in all of them, lightly rubbed the connectors with a emery board to remove scaling? cleaned and re-cleaned and gave em all a shot of wd-40... Well I have to drive about 40 miles in the old boy to push snow this afternoon.... anyone think it could be the fuel pump????Wish me luck MM
Re: 1989 v-6 loses power [Re: METALMOVER] #1076456 02/01/15 02:38 PM
Just changed my mind, gonna go play in the snow for a couple hours right by my house......would rather have it act up within walking distance to my house!!!!!
Re: 1989 v-6 loses power [Re: METALMOVER] #1076457 02/01/15 05:54 PM
Pics or it didn't happen. I like snow. On my tv on the back porch while I'm drinking coffee in shorts and a t-shirt. <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: 1989 v-6 loses power [Re: Mudraider] #1076458 02/01/15 08:44 PM
Well, a good 3 hours of jackin around and plowin my house, 3 neighbors houses a trip to the gas station and didnt miss a beat, my attempt at the wiring tune up must have worked or the cleaning I got from AVPRO...... Ill post some pics here in a bit, hes inside gettin all warmed up and gettin my garage floor all wet...... woooooooohoooooooo. MM
Re: 1989 v-6 loses power [Re: Mudraider] #1076459 02/03/15 03:41 AM
Jay Ayala Offline
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.012s) Memory: 0.6425 MB (Peak: 0.7632 MB) Data Comp: Off Server Time: 2026-07-16 03:42:10 UTC
