Balance chain guide broken bolt #1076565 02/01/15 01:44 AM
A
AcadianaRaider Offline OP
Changing out timing chain, balance chain, oil pump on my 87 Raider due to broke balance chain and everything to this point is going well (thanks to previous posts and pictures I found searching). Problem that I've come to is that the bolt that goes through the top of the balance chain guide (chain guide "A" in FSM), then through the top of the timing chain tension guide and into the block was broken off. I'm sure I can tap the threaded part out, but where can I find this bolt? It is about 2" long with the first 1.5" inches a sleeve (where it goes through the balance chain guide and the last part threaded. I tried looking at Mitsubishi.net, but did not find.
Any help would be appreciated.
Thanks, Jeff
1987 Raider, 2.6L, 5spd, Weber carb
Re: Balance chain guide broke bolt [Re: AcadianaRaider] #1076566 02/01/15 02:56 AM
I have a 2.6L boat anchor motor that I'll be taking the timing cover off of shortly. Post a pic of the specific area and I'll pull the bolt tomorrow.
Re: Balance chain guide broke bolt [Re: AcadianaRaider] #1076567 02/01/15 04:20 AM
A
It's the top bolt on the balance shaft guide in the picture (upper right)
Re: Balance chain guide broke bolt [Re: AcadianaRaider] #1076568 02/01/15 04:24 AM
A
Here's a pic of the broken bolt.
Thanks
Re: Balance chain guide broke bolt [Re: AcadianaRaider] #1076569 02/01/15 02:35 PM
METALMOVER Offline
Do you have a fastenal by you?(or something of the sort) Take the old bolt with you and see if they can match it up. Im visualizing the bolt you have, I think there relatively common, Good-luck METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: Balance chain guide broke bolt [Re: METALMOVER] #1076570 02/01/15 06:31 PM
I'll pull that for you. No problem.
Re: Balance chain guide broke bolt [Re: rxinhed] #1076571 02/01/15 06:59 PM
A
Appreciate it. PM sent with my address. Let me know what I owe you.
Thanks, Jeff
Re: Balance chain guide broke bolt [Re: AcadianaRaider] #1076572 02/01/15 07:30 PM
Kevin C Offline
The factory advises that you don't reuse that bolt. Buy a new one from the dealer or a local parts house. There is a TSB on it and the torque value was increased. Make sure you have a lock washer under the bolts shoulder.
Re: Balance chain guide broke bolt [Re: Kevin C] #1076573 02/13/15 07:10 AM
Kevin C Offline
Superceded PN MD153645
web page
Re: Balance chain guide broke bolt [Re: Kevin C] #1076574 02/13/15 04:01 PM
A
Ordered from Mitsubishi and will be in in a couple of days. Thanks for the part number.
PHP: 7.4.33 Page Time: 0.793s Queries: 18 (0.789s) Memory: 0.6407 MB (Peak: 0.7637 MB) Data Comp: Off Server Time: 2026-10-24 08:20:22 UTC
