Another Shock Question #1076747 02/09/15 10:01 PM
jdavis Offline OP
In the process of swapping the rear end in the Monty, I ended up cutting out the shocks. Just couldn't get the top nuts off and was getting inpatient.
I was just running stock shocks with the OME lift. this time around want to get a longer shock but but none of the manufactures make a shock for lifted Montero.
I'm to worried about brand. Need to know how to go go about determining how long of shock is need then how to find shock. Most website display shocks based on vehicle type.
Thanks,
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: Another Shock Question [Re: jdavis] #1076748 02/10/15 02:40 AM
METALMOVER Offline
I think Id ask the old man, however if you did a 4" lift would you want a 4" longer shock, just my assumption. MM
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: Another Shock Question [Re: jdavis] #1076749 02/10/15 07:05 PM
Try Contacting KYB's tech support team.
When we were looking for longer rear shocks, I contacted KYB (the OEM shock manufacturer for many Montero model years including the 3-position gen II SR shocks). Their tech department was more than patient and willing to help.
I told them we lifted the rear suspension 2" with longer coils and they came up with an alternatively shock that fit my criteria w/ the easiest mount to modify (by removing a metal sleeve that was press fit into a rubber bushing).
HTH! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Another Shock Question [Re: jdavis] #1076750 02/10/15 07:51 PM
Jeep2Montero Offline
Thanks,
~ Jon
The kyb MonoMax stock length front shocks from the Cherokee XJ is the perfect length for running the OME setup on the rear of a Montero, kyb part number 565053. Perfect fit and will ride much better than your stockers.
Epxo rig-98 Montero "SR" with ARB front bumper and 33x9.50's
Trail rig-97 ZJ V8 with long arms and 35's, trailer queen
Re: Another Shock Question [Re: off-roader] #1076751 02/10/15 07:52 PM
And that part number would be?
Re: Another Shock Question [Re: jdavis] #1076752 02/11/15 03:00 PM
Malykaii Offline
When I asked this question a while back, someone sent me a link to a kyb tech sheet that lists every shock they sell by application paired with dimensions. I had a couple ideas but am yet to need the shocks. I don't have the link anymore.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6111 MB (Peak: 0.6987 MB) Data Comp: Off Server Time: 2026-10-22 02:13:58 UTC
