Occasional "Check Engine" light and hard start. #1076774 02/13/15 02:36 PM
Bernoulli Offline OP
The light seems to be coming on more frequently over a month or two. It's been hard to start a couple of times when cold.
From looking at the owners' manual and shop manual I'm guessing EGR valve. The manual says to clean it in appropriate solvent. Does this mean carb cleaner? Any tips?
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Occasional "Check Engine" light and hard start. [Re: Bernoulli] #1076775 02/13/15 03:57 PM
haztoys Offline
Look at the MASS and plug ..How does the truck idle when lights on ?..Open EGR at idle will make a (most) vehicle idle bad ...
Re: Occasional "Check Engine" light and hard start. [Re: Bernoulli] #1076776 02/13/15 05:33 PM
P
pcc Offline
Pulled a code?
I've always found I need manual cleaning as well as solvent (brake fluid) to clean EGR properly. Wire brush, scrapper etc.
Re: Occasional "Check Engine" light and hard start. [Re: Bernoulli] #1076777 02/14/15 12:47 AM
haztoys Offline
Is what we need to do is set up info on what sets the CEL light and what does 'not' set the CEL...
Re: Occasional "Check Engine" light and hard start. [Re: haztoys] #1076778 02/14/15 04:16 AM
Yes!
Re: Occasional "Check Engine" light and hard start. [Re: Mudraider] #1076779 02/14/15 04:48 AM
The owners' manual says the CEL reflects only an emissions problem. I'll check the shop manual again - couldn't find CEL on a fast go through.
Re: Occasional "Check Engine" light and hard start. [Re: Bernoulli] #1076780 02/14/15 05:46 AM
P
pcc Offline
Yes, OBDI & II are there for emissions, but also show improper air/fuel ratio. O2 sensor is to keep CAT healthy and emissions low. Fuel trims keep mixture to 14.7:1. The code sets for an extreme condition that sensors can't compensate for to keep CAT operating.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6155 MB (Peak: 0.6890 MB) Data Comp: Off Server Time: 2026-07-15 18:36:55 UTC
