Priming oil pump #1076838 02/18/15 03:42 PM
A
AcadianaRaider Offline OP
Just finished changing out the balance and timing chains, all guides and the oil pump and am ready to put the front cover back on.
How do I prime the oil pump? The pump is mounted and the timing cover is still off. The fsm mentions priming with 10ml of oil, but is not clear where to add this oil. There is a small cavity at the top of the pump housing that appears to have a small hole at the bottom. Do I add the 10ml of oil there?
I've done a search, and most of the results are related to priming after the timing cover is back on the vehicle.
Thanks, Jeff
1987 Raider, 2.6L, 5spd, Weber carb
Re: Priming oil pump [Re: AcadianaRaider] #1076839 02/18/15 06:56 PM
Jay Ayala Offline
In all of my overhauls with Gen I Monteros, I've never primed the oil pump in the fashion that the manual describes. I've only ever primed the oil pump with the spark plugs removed and the distributor plug grounded.
Re: Priming oil pump [Re: Jay Ayala] #1076840 02/18/15 06:58 PM
Jay Ayala Offline
Oh and turning over the starter for 15-20 seconds so the whole engine is primed. Then I reinstall the spark plugs and break in the piston rings.
Re: Priming oil pump [Re: AcadianaRaider] #1076841 02/18/15 07:43 PM
heathdogg Offline
the only other thing I have ever done is to put the engine assembly lube in the oil pumps to help prime and prevent them from being started up without lube. I heard of vasoline being used, but I don't ever have that in my house.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Priming oil pump [Re: heathdogg] #1076842 02/18/15 07:53 PM
Malykaii Offline
Type in something like "starquest prime oil" into Google and there's a bazzilion write ups on various ways to prime the g54b.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6040 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-10-24 03:17:18 UTC
