Soooo. I was told that a 87 Raider Air Cleaner assembly would work on a 86 Montero and this showed up. Does a 87 Raider really have an opening for the carburetor shaped like the attached image?
Just posting the picture for you in the thread. It makes it easier to view the topic in its entirety rather than clicking on a link to an attachment.
Hmmm... That is weird, why did the picture rotate when I posted it to the thread?
Looks like someone modified a stock air cleaner to fit a Weber. I thought I was the only one to do that. Runs much quieter that way than with the silly little rectangle filter they come with.
I looked closer at it and you are absolutely right! Thanks, now I can get a hold of the junkyard and try to get a refund. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Hahaha. I just E-mailed them about a refund. But since you suggested that I decided I'll just keep it for the day I have to finally have to replace my carb! <img src="/forums/images/graemlins/kewl.gif" alt="" />
That looks a lot prettier than what the previous owner did on mine. He took the bottom of the Weber air filter and glued it to the bottom of the montero air can.
If you got a deal on it and its good work, I say sell it for a profit or keep it,
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
