1990 Montero blew headgasket ... #1076857 02/20/15 04:56 AM
sasnydley Offline OP
So now I am trying to figure out what to do. Rebuild the engine with well over 300,000 miles. Somebody offered a block with 180k. that I would to go home to PA to get. My truck was running fine. Oil is OK. Runs except on 1 cylinder down and smokes like a fog machine.
Re: 1990 Montero blew headgasket ... [Re: sasnydley] #1076858 02/20/15 08:50 AM
danz91crx Offline
find out whats up with the dead cylinder
1990 LWB RS A/T
1990 LWB Base A/T
1991 LWB LS A/T Going...Going...
Re: 1990 Montero blew headgasket ... [Re: danz91crx] #1076859 02/20/15 04:02 PM
haztoys Offline
Do a compression test on the motor to see what the other cylinders are like ... The V6 12 valve motor do go a long time ..
Re: 1990 Montero blew headgasket ... [Re: haztoys] #1076860 02/20/15 05:18 PM
Jay Ayala Offline
I Think you should take Rich up on that engine, overhaul it, then swap it back in to get another 200k out of your gorgeous rig.
Re: 1990 Montero blew headgasket ... [Re: Jay Ayala] #1076861 02/21/15 04:06 AM
I am planing on doing just that. If I had some extra mula to blow I would be getting a diesel package to swap out.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6034 MB (Peak: 0.6673 MB) Data Comp: Off Server Time: 2026-07-09 15:43:04 UTC
